Connecting Rod Cap torque setting GU engine
17 Jun 2019 03:35 #37493
by RandyEma
Replied by RandyEma on topic Connecting Rod Cap torque setting GU engine
Sorry I did not read the whole thread. Yes you will have to retorque the bolts and re cotter . I would probably use no more than 35 pounds because of the old babbit and streaching the old bolts. T
- Thom
17 Jun 2019 01:02 #37491
by Thom
Replied by Thom on topic Connecting Rod Cap torque setting GU engine
Thanks Gary, Thom
- Thom
17 Jun 2019 01:02 #37490
by Thom
Please clairify. Are you saying to leave the cotter pins out where they fell out and hope that the castlelated nuts are tight enough and will not loosten? Just clean out the oil pan and reinstall it? Thom
17 Jun 2019 00:34 #37489
by RandyEma
Leave it alone.R
16 Jun 2019 21:45 #37488
Replied by 1748 S on topic Connecting Rod Cap torque setting GU engine
I have read in these forums that torque wrenches were not in use till WWll. I realize this is not answering your question but someone will come along a give a torque specification to today's standards.
- Thom
16 Jun 2019 20:36 #37485
by Thom
Connecting Rod Cap torque setting GU engine was created by Thom
It was necessary to remove the oil pan on my 8101 Auburn, engine number GU79817. Surprisingly, there was not much sludge in the bottom; however, there were many pieces of the connecting rod cap cotter pins. Last time the pan was off could have been in 1970, I don't remember. Looking in my literature, I can't fine torque settings for the cap castellated nuts, only spacer measurements. My plan is to check the torque setting without removing the nut and replace the cotter pin. What are your thoughts on this plan and does anyone know what the torque number should be?
