CHECK YOUR BRAKE DRUMS
20 Apr 2019 16:44 - 20 Apr 2019 16:45 #37036
Replied by johnmereness on topic CHECK YOUR BRAKE DRUMS
I recall standing out in the green one evening at a Franklin meet where we were all looking at a front brake drum "expanding" on perhaps a 1932 Sedan upon application of the brakes (that would be a drum similar to a Cord L-29) - it was pretty interesting to watch too (they were found a new set of front drums). As a sidenote, the Franklin Club eventually did a run of replacement drums due to "unobtainable" of wire wheel drums and given parts supply of certain cars in the ACD Club I foresee we will be doing the same via an ACD club project/or individual project at some point in time.
Last edit: 20 Apr 2019 16:45 by johnmereness.
19 Apr 2019 03:40 - 19 Apr 2019 03:41 #37032
Replied by mikespeed35 on topic CHECK YOUR BRAKE DRUMS
I am a member of The Riviera owners Association and they have a ad. in their Mag. for aluminum brake drum relining. Don't know if they could reline cast iron drums. J&G relining
www.jgrelining.com
Last edit: 19 Apr 2019 03:41 by mikespeed35.
- rlwardne
17 Apr 2019 22:18 #37023
by rlwardne
Replied by rlwardne on topic CHECK YOUR BRAKE DRUMS
Interesting ideas coming up over there.
I spoke to wildwood at SEMA about disc brakes on my 851. They told me that that figuring it out would be between 15-25k. Beyond that it would
around the cost of a normal conversion kit . The disc maybe could be hidden inside the original drums.
17 Apr 2019 13:37 #37020
Replied by Curt Schulze on topic CHECK YOUR BRAKE DRUMS
You may want to follow this thread :
forums.aaca.org/topic/325517-new-or-refurbished-brake-drums/
17 Apr 2019 13:03 #37019
Replied by 1748 S on topic CHECK YOUR BRAKE DRUMS
Terry I used to do this exact welding in the huge two football field size machine shop I worked in. When a damaged steam turbine bearing area needed rebuilding we could build up the bearing by continous welding a a rotating fixture. Because of the material we needed to keep the bearing area hot around 750 degrees F... That heat was done by huge propane tanks and burners we called weed burners. The welding machine was built by ARP. Fully adjustable welding speed and feed of wire off giant wire spools. Process was simple but setup was very difficult to get correct. It was TIG welding but the welding tip never moved
17 Apr 2019 11:28 #37018
Replied by Terry Cockerell on topic CHECK YOUR BRAKE DRUMS
I read in an engineering magazine a few years ago that brake drums could be built up successfully with continuous welding and then grinding back to size. I intended to save the article with the company name but missed out. I suspect that this process is commercially available and could be tracked down without much trouble.
17 Apr 2019 06:06 #37017
I have 8 cyl fronts NO rears.
I have 6 cyl fronts and rears.
They all started out life with a 12" ID.
I would suggest posting this out in the general discussion board on the AACA site. This problem is not limited to ACD cars.
- George van Nostrand
- Thank you received: 35
16 Apr 2019 23:43 #37015
by George van Nostrand
Replied by George van Nostrand on topic CHECK YOUR BRAKE DRUMS
In Ontario Canada the legal oversize on drums was .060 " I saw one drum that separated as Pete has shown. A total failure !.
16 Apr 2019 17:08 #37014
by pete kelly
Replied by pete kelly on topic CHECK YOUR BRAKE DRUMS
Make sure your drums are safe!
Dont pass up a useable drum.
- rlwardne
16 Apr 2019 14:57 #37013
by rlwardne
Curt told me that their aren’t any new ones. So what’s everyone doing? Other than using up used ones?
16 Apr 2019 14:50 #37012
by pete kelly
CHECK YOUR BRAKE DRUMS was created by pete kelly
The following user(s) said Thank You: auburnandyscar
