Speedometer Fix
- kenswheels
03 Nov 2018 18:30 #35881
by kenswheels
Replied by kenswheels on topic Speedometer Fix
Thanks guys. Finally getting time (and the bad weather) to get this done.
03 Nov 2018 16:33 #35876
Replied by johnmereness on topic Speedometer Fix
Sidenote: The Trip Mileage assembly on 34-36 Auburns is something I have had limited "long term" success fixing - not the highest quality of engineering (at least of any of the ones I have had apart).
I do have to say I love the 9 foot long cable !
24 Oct 2018 15:22 #35816
by ilikescars
Replied by ilikescars on topic Speedometer Fix
You can also use a drill attached to the cable and run it counterclockwise to see if the speedo is functioning
24 Oct 2018 03:35 #35814
Replied by mikespeed35 on topic Speedometer Fix
If the cable is broken, why did it break. You should determine that before replacing the cable if it turns out to be broken. I had a cable break because the speedo was froze up, not ACD car.
- kenswheels
23 Oct 2018 14:43 #35805
by kenswheels
Sounds reasonable, I'll give it a try.
23 Oct 2018 12:59 #35804
Replied by Curt Schulze on topic Speedometer Fix
If you have a Dual Ratio, the speedo cable is 9 feet long ,. disconnect it from the rear axle.
- C.R.D.
23 Oct 2018 12:47 #35802
by C.R.D.
Replied by C.R.D. on topic Speedometer Fix
Can't you just disconnect the cable from the speedometer and drive the car slowly and see if the cable turns? If the cable doesn't turn start there.
- kenswheels
23 Oct 2018 04:13 #35800
by kenswheels
Speedometer Fix was created by kenswheels
Fall is officially here and it's time to start fixing the Cabriolet.
The speedometer (and thus odometer) do not work. Is there a way to determine if it is indeed the cable that's the problem? Could there be any other cause?
My next fix will be the fuel gauge. Stay tuned!
Ken
Ken
