- Thank you received: 18
34-36 Auburn rear floor pan under side finish
- yorkgulch
- Premium Member
08 Aug 2018 13:17 #35186
by yorkgulch
Auburn 851
Replied by yorkgulch on topic 34-36 Auburn rear floor pan under side finish
I repaired the panel but would still like to get a panel fabricated or find a good original.
Auburn 851
07 Aug 2018 22:35 #35177
by ilikescars
Replied by ilikescars on topic 34-36 Auburn rear floor pan under side finish
Did you ever have a new floor pan fabricated, or just repair the old one?
05 Aug 2018 13:47 #35152
Replied by Curt Schulze on topic 34-36 Auburn rear floor pan under side finish
Semi-gloss or black primer is OK for underside. You will find some body color over-spray particularly under the rear fenders.
- yorkgulch
- Premium Member
05 Aug 2018 13:31 #35151
by yorkgulch
Auburn 851
Thanks, Randy and Curt on the second question is semi gloss black or black primer correct for the under side of the body? I guess any undercoating I see on the underside of the body is after market.
Auburn 851
05 Aug 2018 00:37 #35148
I have noted copious amounts of undercoating on the rear wheel tubs and the top of the floor pans, and rear inside pans.
None on the bottom of the floor or the inside of the wheel house.
04 Aug 2018 15:55 #35144
by RandyEma
Replied by RandyEma on topic 34-36 Auburn rear floor pan under side finish
Hello .All I have ever seen is undercoating. R
- yorkgulch
- Premium Member
04 Aug 2018 14:42 - 04 Aug 2018 14:45 #35143
by yorkgulch
Auburn 851
34-36 Auburn rear floor pan under side finish was created by yorkgulch
Should the under side of the rear metal floor pans have sound deadener/under coating or paint? If paint is it black semi gloss ? I have examples both ways.
Craig
Craig
Auburn 851
Last edit: 04 Aug 2018 14:45 by yorkgulch. Reason: Clarify
