1932 Auburn originality questions.
16 Aug 2018 18:51 #35228
Replied by Curt Schulze on topic 1932 Auburn originality questions.
These are front shock links.
- auburnandyscar
13 Aug 2018 16:11 #35214
by auburnandyscar
Check out my build at:
www.1932auburnsedan.com
Replied by auburnandyscar on topic 1932 Auburn originality questions.
"The shock end caps are labelled A,B,C and D for each corner, At least for 31 they are!"
I didn't know that!
now I am going to have to look.
I agree that the 1931's are the "Dogbone" type.
I have no idea what the 'bent' arm is from. Possibly from a wrecked car??
I didn't know that!
11 Aug 2018 20:58 #35204
I have no idea what the problem is. Email me , I'll send you the pix.
11 Aug 2018 20:53 #35203
Brad, see tags on pix
- Brad Hoskins
- Thank you received: 11
11 Aug 2018 19:15 #35202
by Brad Hoskins
31 8-98 cabriolet
Replied by Brad Hoskins on topic 1932 Auburn originality questions.
As I understand the shock links, The 'dog bone' was 31 and the fork was 32-33.
Front levers should be straight
Brad
Brad
31 8-98 cabriolet
- ttcinc
30 Jul 2018 12:23 #35108
by ttcinc
Replied by ttcinc on topic 1932 Auburn originality questions.
Got it
Thank you
Thank you
30 Jul 2018 12:15 #35107
#1 yes
#2 Maybe 33 not 34-36.
#3 Don't throw it away, I might be able to rebuild it if it is 34-36 Auburn. There are other tie rod ends that look similar.
- ttcinc
30 Jul 2018 11:48 #35106
by ttcinc
Curt, To be clear you have the Dog bone (Pic 2 ) on all four wheels? So was the fork used for later models? My Tie rod is both RH threads. So the Ball joint on the right is what was on my car. I thought they were later joints. (And Worn out) Thank you for your help.
30 Jul 2018 11:37 #35105
The link in pix 2 are what is on my cars.
The brake cables have a loom cover.
Pix 5 , the tierod end on the right looks to be 34-36. Has your tierod been converted to left hand thread on one end?
Others can speak to the shocks in pix1
- ttcinc
30 Jul 2018 10:25 - 30 Jul 2018 10:40 #35104
by ttcinc
1932 Auburn originality questions. was created by ttcinc
To all Club members, Thank you for all your support helping me bring my car back correct. Here is a couple new ones. First, The Tie rod ends, Which one is correct for my 1932 100-A? the small one? or the larger style. Second, I took my shocks off to have them rebuilt and I noticed the fronts have two different arms on them, Is this correct? If not what is the correct one? straight or bent? Third, what shock link setup should I have on the car? the Forks or the Dog bones? Forth, Should the break cables be spiraled or gravel guard covered? That is it for now.....
Last edit: 30 Jul 2018 10:40 by ttcinc.
