Turn Signals and Brake Lights
  • Curt Schulze
12 Jul 2018 21:10 #34963 by Curt Schulze
Replied by Curt Schulze on topic Turn Signals and Brake Lights
No trick. The originals were hex , so you can put a wrench on it. The old ones will fail with DOT5 . I can supply a new one that has the hex and will not fail with silicone fluid.
  • kenswheels
  • Senior Forum User
12 Jul 2018 20:30 #34962 by kenswheels
Replied by kenswheels on topic Turn Signals and Brake Lights
Little A, little B.
Checked the lights, they work.
Check the switch...Nothing.
Looks like I need a new one. Any trick to replacing it?
  • Curt Schulze
12 Jul 2018 20:15 #34961 by Curt Schulze
Sure, if the wiring is good and the sockets and the bulb is good. I thought you wanted to check the switch.
  • kenswheels
  • Senior Forum User
12 Jul 2018 20:03 #34960 by kenswheels
Just to cheat, if I connect the 2 studs shouldn't the brake lights come on?
  • Curt Schulze
12 Jul 2018 19:57 #34959 by Curt Schulze
One side has a hot wire . Have someone step on the brake pedal , check the other side and see if there is power there.
  • kenswheels
  • Senior Forum User
12 Jul 2018 19:31 #34958 by kenswheels
Hi Curt.
Found it!
Is there a way I can figure out if it's still working?
  • Curt Schulze
12 Jul 2018 19:00 #34957 by Curt Schulze
A brake booster did not come on your car from the factory. The brake light switch is on top of the brake junction block that is bolted to the LH frame rail near the cowl. If you need a brake light switch, I have new ones that are impervious to DOT5 and judge well.
  • kenswheels
  • Senior Forum User
12 Jul 2018 15:47 #34956 by kenswheels
Thanks for the help guys.
Now, I can't seem to locate the stop light switch. Is it near the booster, on the firewall, or??
The black wire in the attached pic has no mate. It is with the other light wires on the driver side fender/firewall. Any idea what it is for?
Your help is always appreciated!
  • mikespeed35
21 Jun 2018 04:39 #34794 by mikespeed35
Replied by mikespeed35 on topic Turn Signals and Brake Lights
I agree with Jim. Strange phenomenon with lights is usually ground problems.
  • JIM.OBRIEN
  • Premium Forum User
20 Jun 2018 23:28 #34792 by JIM.OBRIEN
Replied by JIM.OBRIEN on topic Turn Signals and Brake Lights
Check your ground. You may have lost it.
  • pete kelly
20 Jun 2018 17:25 #34790 by pete kelly
Replied by pete kelly on topic Turn Signals and Brake Lights
Start with a check to see if the brake switch works then proceed to the turn signal switch wiring.
Good Luck
  • kenswheels
  • Senior Forum User
20 Jun 2018 16:50 #34788 by kenswheels
Turn Signals and Brake Lights was created by kenswheels
Hello everyone.
Upon driving to a show this weekend, my followers noticed that I had no brake lights and when signaling, both sides flashed when signaling left or right.
Any suggestions where I should start looking?
