Oil pump
01 May 2018 23:46 #34549
Replied by 1748 S on topic Oil pump
My guess is this might have been a return from the over pressurization post but..I have never seen this engine oil pump apart. Just a guess.
01 May 2018 15:27 #34545
by RandyEma
Replied by RandyEma on topic Oil pump
Hello. Every oil pump has a pickup and a return so at least two holes ,see if you can figure out the oil routing in that continental engine. R
30 Apr 2018 13:41 #34536
by ilikescars
Replied by ilikescars on topic Oil pump
My guess is to leave it covered as original. The mating surface has no hole for oil to flow through
- the_helmut
27 Apr 2018 21:06 #34521
by the_helmut
Oil pump was created by the_helmut
Hello, I build a new gasket/seal for the oil pump of my 1928 Auburn 6-66 AT. After cleaning the metal and builing a new gasket I see, that there is a hole, that is covered by the original gasket. Is this correct, or I have to cut a hole in the gasket so the oil can flow through it? I circled the hole on the pictures.
Thanks a lot, Christian
