front end alignment for a 1935 Auburn
- Darlene Paul
22 May 2019 18:14 #37291
by Darlene Paul
Replied by Darlene Paul on topic front end alignment for a 1935 Auburn
Thank You Mike,
Paul Pustay
Paul Pustay
15 May 2019 03:51 #37204
Replied by mikespeed35 on topic front end alignment for a 1935 Auburn
How did you check the steering gear? You need two people to check it. Disconnect the drag link and have some one turn the steering wheel as you hold onto the pitman arm and check for play. I'll bet its sloppy and needs adjustment.. If so be sure and do as the owners manual says.
14 May 2019 19:19 #37193
Replied by Curt Schulze on topic front end alignment for a 1935 Auburn
The pitman arm may be oval shaped, the tierod ends may be loose, the worm and sector in the steering box may be out of adjustment. I have seven Auburns sans radial tires and they all go straight down the road.
- Darlene Paul
14 May 2019 18:57 #37192
by Darlene Paul
1935 ,851, while driving car drifts from one side of the lane then to the other side of the lane. Steering gear seems OK. can this be from misalignment.
What's the 1" tube from the steering gear to front wheel. It has springs at both ends.
Could this be to loose.?
Paul Pustay
Paul Pustay
- ken dennison
07 Oct 2017 20:19 #33653
by ken dennison
Replied by ken dennison on topic front end alignment for a 1935 Auburn
thanks for the info
Ken
Ken
06 Oct 2017 16:54 #33644
Replied by johnmereness on topic front end alignment for a 1935 Auburn
I agree with Curt.
That being said though the specs I believe are in the owner's manual and when I had our car done 8 to 9 years ago they put it on a Hunter System and the specs were on the fellows disk for his machine. A good race shop should be able to figure car out.
02 Oct 2017 18:15 #33627
1/8 toe in.
If the car doesn't go into the 'death wobble leave the caster alone.
The following user(s) said Thank You: Darlene Paul
- ken dennison
02 Oct 2017 17:25 #33625
by ken dennison
front end alignment for a 1935 Auburn was created by ken dennison
Any one know the specs for an alignment?
Is there any camper adjustment or just toe in?
