Lubrication in the Steering Box
  • mikespeed35
07 Feb 2021 22:46 #42157 by mikespeed35
Replied by mikespeed35 on topic Lubrication in the Steering Box
I problem with this as many others such as Phillips Dynolife 220 is that the minimum container that is available is 5 Gal. pail.
07 Feb 2021 09:45 #42150 by Joel
Replied by Joel on topic Lubrication in the Steering Box
Sorry, that link didn't work. Go here and search on centra-lube. It is a very viscious liquid anti leak grease. It is available at local suppliers.
www.mystiklubes.com/do/product/665023002
Joel Nystrom
[img
  • ilikescars
06 Feb 2021 23:31 #42146 by ilikescars
Replied by ilikescars on topic Lubrication in the Steering Box
As I have mentioned in an earlier post, I have recommended Super S Cotton Picker Spindle Grease, available at Tractor Supply. Works very well and doesn't leak out of the steering box. Comes in a squirt bottle that allows you to flow the grease into the box without creating a mess. Not expensive, either.
  • mikespeed35
06 Feb 2021 05:34 #42138 by mikespeed35
Replied by mikespeed35 on topic Steering box lubrication
Are you talking about there 460 grease?
05 Feb 2021 05:59 #42116 by Joel
Replied by Joel on topic Steering box lubrication
Here is another anti-leak lube option for steering boxes and differential, available a local oil supply outfits. www.mystiklubes.com/Product.do?code=665023002&category=GREASE
Joel Nystrom
[img
  • mikespeed35
30 Jan 2021 05:24 #42059 by mikespeed35
If that won't work you would need to repair your steering box. On L-29 steering boxes I solder a tube to the bottom steering box plate that extends above the level of the lub. and the horn rod still fits inside it. I also section the end of the bushing by about 1/4 to 1/2" and install a "O" ring to stop the leakage there. Only work if bushing is tight.
  • DONALD.ELMER
  • Senior Member
30 Jan 2021 04:08 #42057 by DONALD.ELMER
Replied by DONALD.ELMER on topic Steering box lubrication
Several years ago you recommended Penrite Steering Box lube because it doesn't leak out. The steering box on my 8-105 leaks like a sieve... do you still think that changing to Penrite is a viable solution? The floor of my garage awaits your advice.
Best,
Don
26 Jul 2009 03:02 #14043 by 26-666
Replied by 26-666 on topic Lubrication in the Steering Box
Hello Everyone,
Just noticed some methods of cleanning parts which I knew nothing about, plastic media blast & dryiceblast sound interesting.
I've heard of using 1 part of molasses to 9 parts of water the remove rust. Has anyone had any success with this method?
Regards
Andrew
Andrew Hines
Margate, Tas, Australia
ACD Club Member
  • mikespeed35
28 Jun 2009 02:48 #13859 by mikespeed35
I don't even bead blast spark plugs. If you look at plugs that have been bead or sand blasted under magnification you will see beads wedged between the electrode and the insulator. Where do you think they go when the plug gets hot in use!
  • oldbanger71
27 Jun 2009 12:18 #13847 by oldbanger71
Replied by oldbanger71 on topic Lubrication in the Steering Box
I would not sandblast the Steeringboxhousing and other technical part because the sand is shot into the housings and get stuck, even if you give it a good wash, later when it's assembled with vibrations all the sand gets shaking loose and with oil or grease in the housing you get the best grindingpaste in your bearings, not realy what you want.
You can give it a plastic media blast or dryiceblast, plastic does no harm if little is left over and dryice leaves no rest anyway or you can use a chemical ruststripper but don't leave it to long in, otherwise it will eat up the surface of seats and glidingsurfaces, make sure to equalize well as it's a acid.
Manny things can be bathed in saladvinigre to derust.
only my two cent <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt=":wink:" title="Wink" /><!-- s:wink: -->
812 310 121 S
  • Bruce Beattie
27 Jun 2009 09:58 #13845 by Bruce Beattie
Replied by Bruce Beattie on topic Lubrication in the Steering Box
ONCE AGAIN..THANKYOU MIKE. I FEAR THAT THIS IS GOING TO BE THE START OF MANY A QUESTION FOR MY 4-44 AS I AM PULLING [size=150:2r1c30ls]EVERYTHING[/size:2r1c30ls] APART. WHILST I'M AT IT, WOULD YOU RECOMMEND GETTING ALL OF THESE VARIOUS PARTS BEAD/SAND-BLASTED PRIOR TO PAINTING?
  • mikespeed35
26 Jun 2009 01:18 #13829 by mikespeed35
Hi Bruce, I use Penrite Steering box lub. It is called a semi fluid grease but will not track like grease but is very heavy and does not leak like diff. lub. It can be purchased from Restoration Supply Co. Phone I-800-306-7008. It is made in Australia and they are the sole supplier in the US. I use it in my L-29 and Auburn with minimal leakage. I rebuilt both boxes with modern seals.
  • Bruce Beattie
23 Jun 2009 09:37 #13809 by Bruce Beattie
Thankyou for that Ken. Much appreciated.
  • Visitor
  • Guest
22 Jun 2009 17:04 #13806 by
Replied by on topic lube
It should have had grease of about the same consistancy as the grease in the differential. and should be about half full, but remember that these seals are not much, so it will leak out. because of the seals and the wear
My 2 cents
Ken
  • Bruce Beattie
22 Jun 2009 09:38 #13804 by Bruce Beattie
Lubrication in the Steering Box was created by Bruce Beattie
Could someone advise me as to what sort of oil should be used in the steering box for lubrication? And should the box be completely filled? (This is for my 1925 4-44)
