Pressure relief on '36 852 radiator
- Lammster1
- Forum User
03 Aug 2022 12:10 #45801
by Lammster1
Replied by Lammster1 on topic Pressure relief on '36 852 radiator
Thanks for your response, John,
I did install a non-pressurized cap and it seems to be running fine. I checked the radiator temp on a hot Chicago day with an infrared heat gun. The radiator seems to run about 185⁰F with no hot spots, and a 10-15⁰F difference from top to bottom.
- Thank you received: 162
06 Aug 2022 03:45 #45812
Replied by mikespeed35 on topic Pressure relief on '36 852 radiator
In my opinion 180+ is too hot. Car should be running 160 with a 160 stat. I also use a 6 bladed fan from Summit. Rad. should be cooling 20 to 25 degrees top to bottom. That is my experiance with my 35 Auburn. My L-29 Cord runs this temp. also.
06 Aug 2022 03:57 #45813
I should add that the rad. core on my 35 Auburn has been replaced with a high efficiency core and the L-29 Cord has a high efficiency core and made thicker. I don't like to screw around with overheating cars!!!
- ACD Club Member
- Thank you received: 125
06 Aug 2022 14:42 #45818
Replied by Curt Schulze on topic Pressure relief on '36 852 radiator
Mike, did those rad. cores come from the UK ?
09 Aug 2022 04:05 #45832
No, local rad. shops. Nothing special, just more fins and tubes. Granted it was 15 to 20 years ago. Also have always used Rad. filters.
- ACD Club Member
09 Aug 2022 13:14 #45834
Mike, so these are modern cores as opposed to the original 'honeycomb' variety ?
Time to create page: 0.129 seconds
