Torque of cylinder head bolt
  • ilikescars
30 Jul 2021 17:22 #43614 by ilikescars
Replied by ilikescars on topic Torque of cylinder head bolt
Schoner Phaeton!
  • EuroMike
  • Non-Member
30 Jul 2021 08:56 #43612 by EuroMike
Replied by EuroMike on topic Torque of cylinder head bolt
All right, got it. After next tour i will let the engine cool down and then will check cylinder head bolts.
Thanks for your help and informations
All the best from Germany
Michael
  • mikespeed35
29 Jul 2021 21:57 #43602 by mikespeed35
Replied by mikespeed35 on topic Torque of cylinder head bolt
Never retorque bolts when hot. Torque specs. are for cold , as Curt says.
The following user(s) said Thank You: 1748 S, EuroMike
  • Curt Schulze
29 Jul 2021 12:50 #43597 by Curt Schulze
Replied by Curt Schulze on topic Torque of cylinder head bolt
I torque it cold after a few heat up, cool down cycles.
The following user(s) said Thank You: EuroMike
  • EuroMike
  • Non-Member
29 Jul 2021 09:07 #43595 by EuroMike
Hello Curt
Thank you for your fast answer. i it better to retorque if engine is warm or do you recommend to do the job at cold engine?
Thank you so much.
It is more or less impossible to get reliable informations here in germany, because there ar only a few cars in germany. I think that my 851 is the only Auburn in germany that is used weekly (as long as weather is dry!)
All the best from germany
Michael
  • Curt Schulze
29 Jul 2021 08:37 #43594 by Curt Schulze
I think that after a few heating and cooling cycles the head should be retorqued.
  • EuroMike
  • Non-Member
29 Jul 2021 08:32 #43593 by EuroMike
Hello Curt
Thank you for your help. Thans to your information the car is back on the road. Th guy in the workshop wants to know wether it is useful to check torque again once engine is warm. He is not 100% shure wether this check is useful or if it may cause damage to the aluminium head.
For your information: The engine has been rebuild 2 years ago by a dutch specialist but we had the idea that the head bolts were not really tight. We think that the not correct tightend screws were the reason for the problem.
Thank you for your ideas.
Michael
  • EuroMike
  • Non-Member
24 Jun 2021 14:18 #43387 by EuroMike
Hello Curt
Thank you for your information. It helps a lot. No i hope to get the car back to road soon.
All the best Michael
  • Curt Schulze
23 Jun 2021 12:20 #43382 by Curt Schulze
Start tightning in the center and work tward the ends. do it in three stages . I torque to 45 pounds. All head bolts have a 'W' on the head.
  • EuroMike
  • Non-Member
22 Jun 2021 12:14 #43376 by EuroMike
Torque of cylinder head bolt was created by EuroMike
Good morning all together!
Currently i have to replace the cylinder head gasket on my 1935 Auburn 851. The car poduced lots of white steam.
I have found a company in Vienna that produces a new gasket according to the sample i sent. Now i need some informations about correct torque of cylinder head bolts. Do we have to tighten the screws in a certain order?
Thank you for any information.
Michael
