1933 8-105 Front Axle
  • pete kelly
  • pete kelly's Avatar
  • Away
  • ACD Club Member
  • ACD Club Member
07 May 2021 20:02 #43092 by pete kelly
Replied by pete kelly on topic 1933 8-105 Front Axle
I must correct myself again.
I found another front axle, 8 cyl SALON with 3/4" king pins and the axle has holes it it where the bijur fittings were, (since replaced with oil cups here)
  • pete kelly
  • Away
  • ACD Club Member
  • ACD Club Member
07 May 2021 20:32 #43093 by pete kelly
Axle # is E61807
  • DONALD.ELMER
  • Forum Contributor
  • Forum Contributor
09 May 2021 02:36 #43096 by DONALD.ELMER
Replied by DONALD.ELMER on topic 1933 8-105 Front Axle
After double checking my axle, I think that is the part number. Does this mean that this front axle center is a standard 1933 8-105 part? I believe that I read that the correct center was a D1046.
So I'm still confused.
09 May 2021 02:56 #43097 by Justin Kerns
Replied by Justin Kerns on topic 1933 8-105 Front Axle
Yes Don it appears you have the correct axle. And the bijur fittings should clear the brake hoses if they thread into the axle at angle and you route the lines immediately down and away from the brake hose like shown in the photos I posted.
Justin
1932 Auburn 12-160A Sedan
1933 Auburn 12-161A Sedan
  • DONALD.ELMER
  • Forum Contributor
  • Forum Contributor
09 May 2021 06:07 #43099 by DONALD.ELMER
There doesn't seem to be a way to insert the Bijur fitting except directly down into the king pin... I will have to double check this tomorrow.
  • pete kelly
  • Away
  • ACD Club Member
  • ACD Club Member
09 May 2021 11:42 #43101 by pete kelly
What we are saying is that the bijur fitting is threaded into the axle on an angle, not onto the king pin. Your axle should have a hole in each end for that.
Time to create page: 0.221 seconds
