36 Auburn rim question
18 Dec 2020 19:27 #41787
by ilikescars
Replied by ilikescars on topic 36 Auburn rim question
Thanks, I replied to your PM
- prattm
17 Dec 2020 13:39 #41782
by prattm
Replied by prattm on topic 36 Auburn rim question
It's possible that it is a 6 cylinder wheel since the bolt circle of the mounting bolts is slightly smaller (5.5 for 8 and 5 for 6).
I sent you a PM on an unrelated topic.
16 Dec 2020 19:33 #41778
by ilikescars
36 Auburn rim question was created by ilikescars
I was attempting to mount some rims & tires onto an Auburn project. Three of the rims fit perfectly but one did not fit. I measured the center bore on the non-fitting rim and found it to be approx 3 3/8" diameter. The fitting rims measured 3 3/4". The non-fitting rim appeared to be exactly the same steel spoke rim. Could it be for a 6 cyl car? I've never seen this before...
