Cleaning 851 dash
  • yorkgulch
  • Premium Member
04 Oct 2020 17:05 #41111 by yorkgulch
Replied by yorkgulch on topic Cleaning 851 dash
Thanks Curt, I hadn't thought of silk screening. I'll probably just get new ones when I get to restoring this one.
Auburn 851
  • Curt Schulze
04 Oct 2020 16:28 #41110 by Curt Schulze
Replied by Curt Schulze on topic Cleaning 851 dash
Craig, silk screening is about the only way to achieve the correct result
  • yorkgulch
  • Premium Member
04 Oct 2020 15:04 #41106 by yorkgulch
Thanks for all the suggestions. I couldn't find Flitz polish so tried a blue remover for motorcycle pipes ( not much effect). Then tried Tarnx silver cleaner. Strong so can leave it on for less than a minute don't rub, wash off. It did a great job in some places but not evenly. Then just cleaned the whole thing with more Tarnx That took off most paint and plating. Got the silver back on the ribbed sections rubbing with aluminum foil . Don't have a good way worked out yet to do black portions.
Auburn 851
  • AuburnNut
21 Sep 2020 16:22 #41025 by AuburnNut
Replied by AuburnNut on topic Cleaning 851 dash
I agree that a new insert is the probably the simplest, and would look great, but who will sell you one and send it through the post. I’d love to know as I’m wanting to buy one myself
  • ilikescars
21 Sep 2020 16:16 #41024 by ilikescars
Replied by ilikescars on topic Cleaning 851 dash
My opinion is: replace the dash insert with a new one. Might save you time and money in the long run
  • johnmereness
20 Sep 2020 16:06 #41014 by johnmereness
Replied by johnmereness on topic Cleaning 851 dash
Probably just a bright nickle wash over the brass and the the black was done - ie why there is not much there to work with - probably looked great for 3 to 6 years when new.
Maybe play on edges with q-tips or fine cloth over a block of wood or .... - figure out is a magic formula
  • yorkgulch
  • Premium Member
20 Sep 2020 16:01 #41012 by yorkgulch
I have some blue magic I think I'll give that a try. I'll definitely coat it if have any luck cleaning it up. This is for a car I don't plan to restore. I'm wondering if some kind of silvering process was used as it looks the color of very tarnished silver.
Auburn 851
  • johnmereness
20 Sep 2020 15:51 - 20 Sep 2020 15:52 #41011 by johnmereness
As a sidenote: If water applied makes them look half way decent - then can you just leave them alone/hands off and apply a gloss or a satin clear-coat ?
Last edit: 20 Sep 2020 15:52 by johnmereness.
  • johnmereness
20 Sep 2020 15:49 #41010 by johnmereness
You could try Filtz polish, Never Dull, Blue Magic Chrome cleaner, or ...
My opinion is no light at the end of the tunnel. I did clean up a set and for the most part it left the chrome trim removed showing brass and the painted areas a tarnished brass look. I have seen people polish them as brass and I have also seen people do a bright chrome "wash" on them too. And of course reproduction is an option.
  • rlwardne
  • Senior Member
20 Sep 2020 04:10 #41003 by rlwardne
Replied by rlwardne on topic Cleaning 851 dash
Try Flitz polish
  • yorkgulch
  • Premium Member
19 Sep 2020 21:28 #41000 by yorkgulch
Thanks Curt I have a set that someone did that to.
Auburn 851
  • Curt Schulze
19 Sep 2020 20:36 #40999 by Curt Schulze
Craig, I am sorry to have to tell you there is no Santa Claus . The base metal is brass and you will go thru the ultra thin plating & paint.
  • yorkgulch
  • Premium Member
19 Sep 2020 16:59 #40997 by yorkgulch
Image in previous post shows panel half wet and half dry
Auburn 851
  • yorkgulch
  • Premium Member
19 Sep 2020 16:35 - 19 Sep 2020 16:38 #40995 by yorkgulch
They are it appears the black diagonals were painted on but I'm guessing that the silver base is some sort of plating. Maybe something like a silver polish might clean it without removing the black paint.
Auburn 851
Last edit: 19 Sep 2020 16:38 by yorkgulch. Reason: Correction
  • Curt Schulze
19 Sep 2020 15:55 #40994 by Curt Schulze
Craig, I assume the dash inserts are the diamond cross hatch variety.
  • johnmereness
18 Sep 2020 21:04 #40985 by johnmereness
Would you post a photo ?
  • yorkgulch
  • Premium Member
18 Sep 2020 15:33 #40980 by yorkgulch
Cleaning 851 dash was created by yorkgulch
The dash panels on my 851 cabriolet have darkened almost to black in the areas that were silver . Ive tried cleaning with soap and water with no luck. Is there anything that will clean that up without removing the black paint sections.
Auburn 851
