852 SC lubrication
- EuroMike
14 Aug 2020 09:34 #40716
by EuroMike
Replied by EuroMike on topic 852 SC lubrication
Hello Pwestphal
If it is possible please send a pdf or jpg file to [email protected]
Thank you so much for your help.
I picked up my 851 Phaeton Sedan Tuesday and now i start to collect as much information as possible in order to do the regular maintenance and keep the car in running condition.
Thank you.
Best regards from Germany
Michael Friess
Thank you.
Michael Friess
13 Aug 2020 21:05 #40714
Replied by Curt Schulze on topic 852 SC lubrication
Put modern sealed bearings in the water pump and the throw-out bearing.
I only sell parts cash and carry.
- Pwestphal
13 Aug 2020 19:12 #40713
by Pwestphal
Replied by Pwestphal on topic 852 SC lubrication
Thank you. What about the cups, like the water pump?
My parts book has yet to arrive, hopefully today and I will be sending you a parts list.
Thank you.
Thank you.
- Pwestphal
13 Aug 2020 19:10 #40712
by Pwestphal
Happy to send it to you. Give me an address.
- EuroMike
13 Aug 2020 16:34 #40711
by EuroMike
Hello Curt
Thank you for your fast help!
Michael Friess
Michael Friess
13 Aug 2020 16:30 #40710
Leave the 3/4 plug out, when the lube starts coming out, you have enough.
The following user(s) said Thank You: EuroMike
- EuroMike
13 Aug 2020 15:00 #40708
by EuroMike
Hello Curt
Thank you for your quick answer. I have already orderered gear oil SAE 90 EP in order to fill up the rear diff. Do I have to fill up to the plug 3/4 or to the small plug 1/4 in the rear cover of the diff? Thank you for your help. Best regards Michael
13 Aug 2020 14:15 #40707
Having owned and restored 20+ Auburns, I have had success with a good quality 80 / 90 gear lube in the rear diff and trans & Shell Rotilla T 15 / 40
in the engine.
in the engine.
- EuroMike
13 Aug 2020 13:50 #40706
by EuroMike
Hello Pwestphal
I am new Auburn owner as well. I am sorry, but i have no informations which oils will replace the ones in the Esso lubricant diagramm.
Is it possible for you to send me a copy of the diagramm by mail so that i can better identify the points of lubrication?
For the rear axle, i think classic gear oil SAE 90 EP is the right.
Michael Friess
Michael Friess
- Pwestphal
27 Jul 2020 02:01 #40609
by Pwestphal
852 SC lubrication was created by Pwestphal
As a new Auburn owner I’m seeking advice on what lubricants to use. With the car I received this handy Esso lubricant diagram with recommenced lub. Well you can’t find Esso products in the US and 84 years have passed. Do we have a recommenced list for the 23 points of lubrication. Thank you.
