Spring Steel bumper repair
- DONALD.ELMER
- Senior Member
24 Dec 2020 05:33 #41812
by DONALD.ELMER
Replied by DONALD.ELMER on topic Spring Steel bumper repair
I wish I could describe some obscure and mysterious fix but truth be told, I got in touch with Denny Akers here in the Seattle area and Denny put me in touch with a fellow who understood the problem immediately and had the experience to accomplish the fix. In a nutshell, he drilled a small hole at the interior end of the fissure and then rewelded the fissure.
During the course of the restoration of my 8-105, I've had the pleasure to come in touch with a number of older people with years of experience with obscure problems. Most of these fixes are not accomplished overnight--for them, time is not measured by sweep hand on the clock, so patience is required.
If anyone in the Northwest needs help, call me and I'll be happy to connect you with an old-timer with whom I've become acquainted.
- DONALD.ELMER
- Senior Member
24 Dec 2020 05:33 #41811
by DONALD.ELMER
- AuburnNut
19 Dec 2020 17:48 #41790
by AuburnNut
Replied by AuburnNut on topic Spring Steel bumper repair
Donald. That’s fantastic that you have been able to solve your problem. For the benefit of members like myself, I’d certainly appreciate you telling us how your problem was solved. The fantastic thing about this forum is that we share our problems so we can all benefit from the solution. How did you have success?
- DONALD.ELMER
- Senior Member
19 Dec 2020 06:10 #41788
by DONALD.ELMER
All this has been done successfully. Bumpers are now installed.
19 Jul 2020 19:29 #40550
Replied by mikespeed35 on topic Spring Steel bumper repair
Contact a top end restoration shop in your area and see who they use.
- DONALD.ELMER
- Senior Member
18 Jul 2020 19:58 #40545
by DONALD.ELMER
Does anyone have suggestions for a "good" plating shop in the Northwest... or anywhere for that matter?
16 Jul 2020 20:57 #40535
"GOOD" plating shops can handle that kind of work. Have the shop plate it also, so all the responsibility is on one shop.
The following user(s) said Thank You: DONALD.ELMER
16 Jul 2020 18:40 #40534
Replied by johnmereness on topic Spring Steel bumper repair
I assume it becomes a "silver solder" project as you need to weld with a material that will accept plating ?
- xjn001
16 Jul 2020 09:03 #40531
by xjn001
Replied by xjn001 on topic Spring Steel bumper repair
Please show photos of damage.
- DONALD.ELMER
- Senior Member
16 Jul 2020 04:19 #40529
by DONALD.ELMER
Spring Steel bumper repair was created by DONALD.ELMER
I need help! The front bumper for my 8-105 Salon was damaged years ago and I need to find someone who is capable of working on Spring Steel. Any suggestions would be quite welcome.
