Mystery solved? Advice wanted
- Neal Ziff
05 Jul 2010 13:23 #17264
by Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
Replied by Neal Ziff on topic Mystery solved? Advice wanted
Thanks Mike - I'll do both
Neal
Neal
Neal
_________________
1930 8-95 Cabriolet
05 Jul 2010 02:36 #17258
Replied by mikespeed35 on topic Mystery solved? Advice wanted
Neal, checking for cracks is good but make sure the head is flat too. I use Copper Coat gasket sealer.
- Neal Ziff
04 Jul 2010 21:48 #17253
by Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
Thanks for all the suggestions. I purchased a NOS gasket, but haven't yet had time to remove the head to replace it. I plan on having the head checked for cracks before I reassemble. Should I assemble it dry or use something like Permatex with it?
Neal
Neal
Neal
_________________
1930 8-95 Cabriolet
- Mike Dube
04 Jul 2010 19:26 #17250
by Mike Dube
8-100A
Replied by Mike Dube on topic Mystery solved? Advice wanted
Another good source is Paul Terhorst, a fellow ACDer. He distributes Olson's gaskets and he & Sandy are good friends.
8-100A
- curt
04 Jul 2010 19:16 #17248
by curt
Replied by curt on topic Mystery solved? Advice wanted
Neal, a good source is Olsons (Olsens?) gaskets
Curt Warner
Curt Warner
- Neal Ziff
03 May 2010 03:44 #16643
by Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
Sorry I didn't include the vitals.
1930 8-95 Cabriolet
Neal
1930 8-95 Cabriolet
Neal
Neal
_________________
1930 8-95 Cabriolet
03 May 2010 01:07 #16642
What year Auburn, and is it a 6 cyl. or 8 cyl. 6 cyl. are more readly available than 8 cyl.
- Neal Ziff
01 May 2010 15:30 #16631
by Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
Mystery solved? Advice wanted was created by Neal Ziff
I have always wondered why the Auburn which my father purchased for $50 was left sitting and abandoned some 60 years ago. As we worked to get it started and driving I kept expecting to have that ?Ah Ha!? moment when the mystery would be revealed. Here?s the conclusion:
Since getting it going, I?ve been driving it a few miles here and there to work out the kinks. It keeps getting too hot. The water is circulating and the radiator is functioning well, so we tested the radiator fumes and have come to the conclusion that the head gasket is leaking. Maybe this was the reason it was parked and the repair never made?
Just as with all the other work I?ve done to get this far, I?ve never torn an engine apart either. I?ve seen the Ad in the newsletter by Peter Horst for gaskets. Is this the preferred source? Any other recommendations? Any comments or suggestions on proceeding with this task?
As always, thanks for help,
Neal
Neal
Neal
_________________
1930 8-95 Cabriolet
