leather oil seals
  • Neal Ziff
  • Neal Ziff's Avatar Topic Author
  • ACD Club Member
  • ACD Club Member
06 Jul 2009 04:47 #13936 by Neal Ziff
Neal Ziff created the topic: leather oil seals
Before I reassemble my rear brake/hub assembly onto the car I want to replace the leather oil seals. Does anyone know where I might find these? Are they available or do I need to make my own? Do they come "formed" or are they flat and then shaped by the beveled end of the hub?
I'm trying to attach an image here, if it works it will give a better idea of what I'm talking about.
Neal
http://s745.photobucket.com/albums/xx99/NZiff/?action=organize
Neal
_________________
1930 8-95 Cabriolet
  • Neal Ziff
  • ACD Club Member
  • ACD Club Member
06 Jul 2009 04:50 #13937 by Neal Ziff
Neal Ziff replied the topic:
guess I'm going to have to work on that image posting routine
Neal
_________________
1930 8-95 Cabriolet
  • Neal Ziff
  • ACD Club Member
  • ACD Club Member
06 Jul 2009 04:59 #13938 by Neal Ziff
Hey, I did it! So, do I have any suggestions?
Neal
_________________
1930 8-95 Cabriolet
06 Jul 2009 08:22 #13939 by oldbanger71
oldbanger71 replied the topic:
From the look, i would say best is to get your self a good sealcutter (cuts the inside and outside circle at once) organize good quality flat lether for mechanical purpos slightley thicker than the one you have and as well a little larger so a light pressfit is arrived and give it a good oil soak mount it and when it all comes together it will be selfshaping.
Otherwise you could also get professionaly a modern seal crafted into the assembley, this conversion would happen only once and then you can replace it your self as needed.
This is only my two cents, since i don't know your assembley and can not juge you skills.
Good luck. <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt=":wink:" title="Wink" /><!-- s:wink: -->
812 310 121 S
  • mikespeed35
  • mikespeed35's Avatar
06 Jul 2009 17:28 #13940 by mikespeed35
I am not that familiar with your car but I always replace the seals with modern lip seals. Some times it is necessary to have some machine work done to accomplish this. It looks as though "F" is a inner oil seal. I would replace that with modern also. Find the shaft and flange size and find a seal that will work. I find that I can usually find a seal with the right shaft size, it's the flange size that is usually the problem. Some times you can make a sleeve to adapt the flange size or have it machined. It requires some research. Good luck.
necessary Mike
06 Jul 2009 18:44 #13942 by Tom_Parkinson
Tom_Parkinson replied the topic:
Neal,
Isn't it nice to be RE-assembling this recalcitrant hub and axle, rather than still DIS-assembling?
Time to create page: 0.199 seconds
