Fast rust removal
14 Jun 2009 16:27 #13755
by Tom_Parkinson
Replied by Tom_Parkinson on topic Skinned knuckles
Bill--did the Bar Keeper resist your taking his friend? Is that where the skinned knuckles came from? <!-- s:lol: --><img src="{SMILIES_PATH}/icon_lol.gif" alt=":lol:" title="Laughing" /><!-- s:lol: -->
- oldbanger71
01 Jun 2009 09:51 #13648
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic Fast rust removal
If you don't want to rechome all, you can cover just the horizontal flats with a very light epoxyfilm rather poored on than sprayed, maybe some polishing might be a good idea before epoxy is applyed.
This is only a cheap way to fix.
I much rather would go for rechrome, as i like to fix things propperly.
this is only my two cents.
812 310 121 S
- bill powell
21 Oct 2007 15:53 #8444
by bill powell
Replied by bill powell on topic Fast rust removal
A very fine steel wool and car wax does a great job on that rust haze that appears on most of the modern chrome plating. To keep the rust off, keep a coat of wax on it. No Oxygen, no rust.
That won't help you on the deep pitted rust.
I'm sure most of you know it, but for those of you who don't, Chrome plating is a clear coating, put on to protect polished nickel. Bits of sand and other flying objects make pin holes through the chrome and nickel, allowing the steel to rust.
Chrome plating is supposed to be a three step process, but most of the cheaper chrome shops, the ones with the flat rate attitude, skip one of the steps and makes the plating job prone to rust.
21 Oct 2007 03:14 #8442
Replied by mikespeed35 on topic rust remove
Bill, If that is your hand in the picture, congratulations, You do more than just punch computer keys so well. I notice the skinned knuckles.
- Bill Hummel
20 Oct 2007 16:43 #8441
by Bill Hummel
Replied by Bill Hummel on topic Rust
This is only a quick and dirty way to remove it. I suppose I would have to get the piece stabilized with some sort of covering, but I will probably just go ahead and get it rechromed.
20 Oct 2007 12:17 #8440
by ilikescars
Replied by ilikescars on topic rust
Yes, but how do you keep it from returning?
- Bill Hummel
19 Oct 2007 14:26 #8434
by Bill Hummel
Fast rust removal was created by Bill Hummel
For light rust, BAR KEEPERS FRIEND works very well. Looks like Ajax powder but won't scratch surfaces. Works fantastic on almost all metals. The grille on this 1941 Chevy truck has been damaged by the rust, but at least the rust was removed very easily.
Popular Science says wet aluminum foil will remove rust and it kinda did. But it does not work nearly as well as BKF.
Elapsed time on this truck grille was 7 minutes.
