POR-15 Chassis sealer question
- curt
07 Oct 2007 22:30 #8312
by curt
Replied by curt on topic POR-15 Chassis sealer question
I would only caution that you are using adequate respritory protection. Unless the formula has changed, POR-15 contains isocyanates (think cyanide) so a forced air system is required.
- Duesey
03 Oct 2006 02:10 #5539
by Duesey
POR-15 Chassis sealer question was created by Duesey
I will soon be starting the daunting task of completing sealing the rear end of a 37 Packard with POR-15 chassis sealer. I know I have to put on two prep coats of POR-15 paint (think, black paint) and then a coat of the chassis sealer. I have wire brushed most of the surfaces that I will be working on and will be finishing up the wire brushing prep when I can.
My question is if any of you have done this, do you have any tips for me? I have never done this before so I am flying blind, any advice is greatly appreciated. Thanks
