Ethanol makes my cars inoperable
18 Jun 2013 01:11 #25449 by Tom Georgeson
Tom Georgeson replied the topic: High temp
Josh,
I meant to ask if you have thermostats in your housings? Is your engine running when you put the infra-red gun on them? Could you be getting reading off your exhaust manifold that are slewing the reading? The thermostat housings are very close to the exhaust manifolds. It would seem that if the water in your top tank is 150-160 degrees you shouldn't worry!
  • Josh Malks
  • Josh Malks's Avatar
  • ACD Club Past President
18 Jun 2013 02:16 #25451 by Josh Malks
Josh Malks replied the topic:
Yes, I have thermostats. Don't remember the exact circumstances, but if the engine had just been stopped heat could indeed flow into the thermostat housings from the exhaust manifolds for a few minutes. Next time I run the car I will check more carefully and report before I take any action.
18 Jun 2013 17:39 #25453 by Tom Georgeson
Tom Georgeson replied the topic: Airtex fuel pump
Just got a reply from Airtex Products and they say that the E8902 is a diaphragm pump and that it is combatable with all modern fuels. I will still use it as it only puts out 2.5-4.0 PSI while the other one (E8011) puts out 5.0-8.0 PSI, too high for our cars.
Time to create page: 0.055 seconds
