Auburn 898
- Kees Richie
18 Apr 2006 18:20 #4731
by Kees Richie
8 cylinder nut
Replied by Kees Richie on topic Cam lobe modification
Hi Bob,
Please be more specific in detail about your modification.
What is model number of Delco Remy Dist. from which you
used the parts?
Thanking beforehand,
Kees
used the parts?
Kees
8 cylinder nut
18 Apr 2006 00:41 #4725
by ilikescars
Replied by ilikescars on topic Distributor
Bob: That is very interesting. Was the old four-lobe worn out in any way? Also, would you be interested in selling your left-over distributor parts? I'm trying to reconstruct a S/C distributor that had been switched over to electronic ignition.
Regards, Mark
Regards, Mark
- bob hale
17 Apr 2006 12:47 #4715
by bob hale
Regards,
Bob Hale
Auburn 898 was created by bob hale
Hello, I thought some of you might be interested in this. I have just changed my distributator centre pole from a 4 lobe twin set of points, to a 8 lobe single set. using parts from a delco remy Buick, It was done in about 2 hrs.
and has made a BIG difference in pulling power. Bob in England
Regards,
Bob Hale
