Casting Numbers on a Model J Block?
- Chris Summers
Always interesting comparing notes on these old things.
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
- Bob Roller
Raydon Thompson once had a Kissel with a 420 CID flathead engine and the entertwined initials IH on the rear over the bell housing.The engine was not original to the Kissel and International trucks had nothing like it so it still remains a mystery. The head gasket blew and that's how the bore and stroke were discovered to be the same as a stock "J".It may have een an industrial engine by an obscure and now long gone/forgotten maker.
Bob Roller
Bob Roller
- Joel
Bob Roller wrote: Lycoming did cast other large blocks for trucks that had identical CID of 420 when finished.
Bob Roller
FYI: George Albright investigated the other Lycoming 420 block for the possibility of converting one to a Duesy block. They are completely different. The truck block is a flat head.
- Bob Roller
Bob Roller
Bob Roller
- alsancle
- Thank you received: 15
alsancle wrote: I was wondering if all blocks had this number cast? Unfortunately the other block I have access to is off at the machine shop so I didn't have another to compare.
Well, I've got a picture of at least one other block with the exact same casting so I'm guessing it present on all the other blocks too.
- alsancle
- Chris Summers
I expect that Randy will provide the real answer soon.
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
- Chris Summers
(pardon the size but I wanted to make sure everyone could read it)
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
- alsancle
