Engine cranks slow after hot
  • ilikescars
  • ilikescars's Avatar Topic Author
  • ACD Club Member
  • ACD Club Member
10 Aug 2010 14:28 #17546 by ilikescars
ilikescars created the topic: Engine cranks slow after hot
Hi: I have a small problem with my 851 '35 cabriolet: If I drive the car for awhile and shut it off for a minute, it has a tendency to crank very slowly before starting again. (I have adjusted the timing correctly.)
I read some posts on other websites that suggest that the starter motor is getting overheated from engine heat and causing it to lose cranking ability.
Or maybe I should have the starter gone through by a rebuild shop?
Any suggestions?
  • 's Avatar
  • Visitor
  • Visitor
10 Aug 2010 22:35 #17554 by
replied the topic:
Put a parallel induction ammeter (600 amp) along the battery cable and crank it. If it pegs the ammeter, re-build the starter. This is not 100 %, but close enough to warrant doing it.
  • mikespeed35
  • mikespeed35's Avatar
11 Aug 2010 01:51 #17557 by mikespeed35
I presume you have heavy battery and startex cables? Positive to frame and then frame to starter?
  • Josh Malks
  • Josh Malks's Avatar
  • ACD Club Past President
11 Aug 2010 13:27 #17559 by Josh Malks
Josh Malks replied the topic:
To supplement Mike's response, battery cables should be 00 welding cable with professionally crimped (not hobbyist soldered) terminals. Ground cable (not strap) should run from battery terminal to one of the mounting bolts on the starter.
Use an Optima battery.
Do have the starter checked by a competent shop. Worn bushings will permit the armature to move closer to the field coils as it rotates which will cause drag.
  • ilikescars
  • ACD Club Member
  • ACD Club Member
11 Aug 2010 13:28 #17560 by ilikescars
ilikescars replied the topic:
Mike; Yes, everything is correct. I have a feeling that there is a poor ground inside the starter motor. I discovered that problem in another starter that I have.
Bill: I don't have the testing device that you mentioned, but I will try to borrow one...
  • ilikescars
  • ACD Club Member
  • ACD Club Member
11 Aug 2010 13:32 #17562 by ilikescars
Josh: The ground is a braided strap, same as factory. I even used dielectric grease on the contact points. Thanks for the info.
Time to create page: 0.047 seconds
