L-29 Flywheel
- meredith
03 Jul 2012 16:43 #23133
by meredith
Replied by meredith on topic L-29 Flywheel
GOT IT!
When in doubt, get the biggest crow bar you can find!
Thanks to everyone who responded. The flywheel is off.
I am glad we have the Cord L-29 Forum.
Cheers,
John Meredith
Cheers,
John Meredith
02 Jul 2012 10:22 #23132
by
Replied by on topic Flywheel
There should be two threaded holes to screw in bolts through the flywheel to put pressure against the crank. , but if they are not there you can just use a pry bar and keep changing positions. The line-up pins do fit very tight.
K Clark
K Clark
01 Jul 2012 23:11 #23129
Replied by mikespeed35 on topic L-29 Flywheel
I have not had to us a puller to remove the flywheel. There must be another problem.
- meredith
01 Jul 2012 15:00 #23128
by meredith
Hi Ken,
It isn't the ring gear. That is machined onto the flywheel. It is the flywheel attached to the crank. There are 6 bolts and 2 studs. Bolts have been removed. But, pulling the flywheel is a bear and I do not want to damage anything. Is there a specific commerical puller that anyone knows about for this size of flywheel?
Cheers,
John
Cheers,
John
01 Jul 2012 11:17 #23127
Replied by Curt Schulze on topic Flywheel
Ken, it sounds like John is having trouble removing the flywheel from the crank, not the ring gear from the flywheeel.
01 Jul 2012 10:19 #23126
by
If it is an original and has not already been cut for the replacement ring gear, it does not come off. they were machined as a unit.
K Clark
K Clark
- meredith
30 Jun 2012 15:42 #23118
by meredith
L-29 Flywheel was created by meredith
To All,
Does anyone have a suggested method for removing the flywheel off an L-29 engine? Does anyone know of a specific commerical puller for this job?
Please let me know.
Thanks!
John Meredith
Please let me know.
Thanks!
John Meredith
