L-29 exhaust pipe and C-pipe
- 1930 Jordan
- Senior Member
01 Feb 2006 09:02 #4307
by 1930 Jordan
1930 Jordan"G" line 90,1953 Plymouth,1951 Chrysler Saratoga,1975 Dart,1974 Schwinn Collgate,1978 Schwinn Continental,1971 Honda 500"4",1973 Honda 350"twin",1975 Honda 500"twin",1955 Norton,1988 Honda Shadow custom,05 crossfire roadster.
Replied by 1930 Jordan on topic help with lister wrap and boiler plaster
I just found this web page and I think that I may have something that will work for the Boiler plaster and the Lister wrap. If some one could send me a sample of what the Lister wrap is to look like, I think that I may have something at work that may work for you L-29 owners. I have a 1930 Jordan great line 90, that I have been working on and have used some of the materials from work to wrap the last part of the header, and part of the pipe past the cowling area because this is right up against that area and gets real HOT. My floors are wood right there, I did not want any kind of fire with this car for their is only 8 1930 Jordan's, and this is one of the 3,1930 5pass sedans. I am a Engineer at a IL hospital and work with the boilers. I am around this kind of thing all day so if you think that I could help let me know. P.S. just love this sight- I have come away with LOTS of info that has helped me with LOTS of ???????? that I have had about the L-29's. I am hopping that one day I could afford to get one of the L-29. <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
- Al Hatch
21 Jun 2004 19:14 #1852
by Al Hatch
Replied by Al Hatch on topic L-29 exhaust pipe and C-pipe
Ken,
Regarding the asbestos question; I have found that if you go to 'an older' hardware store they may have the asbestos wrap still sitting on the shelve. I recently found some at a local hardware and it was the type that had to be soaked in water before applying (I used it on the muffler of the S/C 812 Cord) and it just happen to be 2" wide.
Just another thought for you L-29 guys.
CORDially,
Al Hatch
CORDially,
Al Hatch
- K Clark
21 Jun 2004 00:44 #1845
by K Clark
Replied by K Clark on topic Technical Information
Thanks Dick and Stan for the input.
I like to do the most correct restorations possible. I agree with you both on the information, on the paints and exhaust wrapping.
Ken
Ken
- Dick Greene
20 Jun 2004 23:22 #1844
by Dick Greene
Replied by Dick Greene on topic L-29 exhaust pipe and C-pipe
The C-shaped exhaust wrap on the L-29 was originally a 2" wide "lister wrap" which was then used on boilers. It was basically asbestos, which, as Stan says, has been removed to protect us. I always felt that if you didn't eat it, mix it with milk in a blender, and pretend it was spun cotton candy, it wouldn't hurt you. Granted, an overdose of anything will harm you, like drinking way too much water.
Anyway, back to the asbestos wrap. The original, 6400+ mile sedan we own has the 2" wrap with 48 turns, which ends about 8" short of the end of the pipe under the engine/trans mount. A clamp on each end with two intermediate hold it well. An old plumber told me the material was soaked in water first, then applied and allowed to dry. It took a shape to the pipe and stayed with the clamps.
The sock, or "Chinese finger bandage" looks great, and was found on my 1932 Cabriolet when I bought it in 1956 -- the car had been "repaired" not "restored", but probably had the sock put on in the '50s.
There are "asbestos-like" products available that really look the same as the original, especially after being heated by the hot exhaust pipe. If you opt for the sock, it is easier to apply, looks neater, but is not original.
Dick Greene
Dick Greene
- Auburn/Cord Parts
23 Jan 2004 19:09 #1227
by Auburn/Cord Parts
Replied by Auburn/Cord Parts on topic RE: L-29 exhaust pipe and C-pipe
The original material was asbestos and boiler plaster. None of the original materials are available today. We are forced to offer a Nomex glass woven sock which is different in appearance. It has always been acceptable in judging for the above reason wether we like it or not. Our government is protecting us to death.
Stan
Stan
- K Clark
23 Jan 2004 02:33 #1221
by K Clark
L-29 exhaust pipe and C-pipe was created by K Clark
To Whom can answer:
I'm in question to what kind of insulation wrap should be on the C-pipe and the header pipe of the L-29 Cord. I have seen all kinds. The first four L-29's that I restored I was able to get a woven sock. what I thought was the best, and the best looking, from Stan Gillian., but the next time I ordered the sock it was of a much larger weave, more difficult to put on but with a little pursistance I felt it looked fine. I have seen some with a two inch wide wrap, and some that look molded?. also should the wrap be brought all the way to the muffler or should it only go to the engine mount cross member?. What is the most exceptable or are all the different ways OK???
Thanks Ken Clark
Thanks Ken Clark
