Trans Mainshaft Runout
17 Mar 2018 17:26 #34322
Replied by 1748 S on topic Trans Mainshaft Runout
Thanks for this information Jim. My measurements were taken on my craftsman 12 inch lathe using a 3 jaw chuck. Run-out has not been checked on the lathe because its new to me. I purchased it reciently. So my plan is to build a set of V blocks using 2 roller bearing on each piece. then rest the shaft in the rollers and recheck my run out. I will post pics and readings then.
17 Mar 2018 01:39 #34316
Replied by JIM.OBRIEN on topic Trans Mainshaft Runout
At 8 thousands runout the gears will bind. Replace the shaft
20 Feb 2018 22:44 #34217
Trans Mainshaft Runout was created by 1748 S
I understand zero runout is desireable but what is the replacement runout on the trans long manishaft? Mine appears to be 8 thousands but I do not have a set of roller V blocks yet. Thanks all.
