Gas Tank
  • 1748 S
  • 1748 S's Avatar Topic Author
  • ACD Club Member
  • ACD Club Member
02 Jan 2017 04:11 - 02 Jan 2017 04:18 #32148 by 1748 S
1748 S created the topic: Gas Tank
This is what the gas tank suction line looks like in our tanks. No idea why it has to be fastened to the bottom of the tank by the copper rivet and the soldiered on copper tab but it was. It will NOT be replaced like that. No reason for it to be fastened to the bottom drain flange like this.
Last Edit: 02 Jan 2017 04:18 by 1748 S. Reason: added pics
02 Jan 2017 07:09 #32150 by Frank L
Frank L replied the topic: Gas Tank
So how are you planning to fasten the suction pipe?
It will need to be fastened to the bottom of the tank somehow.
  • 1748 S
  • ACD Club Member
  • ACD Club Member
02 Jan 2017 16:57 #32151 by 1748 S
1748 S replied the topic: Gas Tank
In all the diesel or gas fuel tanks I have been inside of never have I seen the suction line fastened to anything in the tanks.If you know why please tell me because making a mistake is not my plan. Usually a suction line is close to the bottom of any tank and if you look at any modern gas or diesel suction level sender. they are not fastened to any part of the bottom of the tanks. The only reason I went thru removing this suction line is mine was plugged up. nothing was cleaning it out either. Even some 20 year old no longer available carb cleaner would soften or cut this.
03 Jan 2017 13:28 - 03 Jan 2017 13:30 #32196 by Frank L
Gary,
I would not want a copper pipe of any length to dangle unsupported . It might crack due to vibration.
Just my 2c. As Cord(presumably) took the trouble to secure the pipe, so would I.
Frank
Last Edit: 03 Jan 2017 13:30 by Frank L.
  • 1748 S
  • ACD Club Member
  • ACD Club Member
03 Jan 2017 19:38 #32212 by 1748 S
Thanks Frank. I recognise what you are stating. I can reattach this but it will be plenty of trouble doing so.
Time to create page: 0.174 seconds
