Bolt head markings
05 Aug 2016 11:22 #31467
Replied by Curt Schulze on topic Re: Bolt head markings
High hex grade 9 bolts with W, N, 30 (raised marking) are available in most popular sizes.
05 Aug 2016 03:40 #31464
Replied by mikespeed35 on topic Re: Bolt head markings
If you are going to use "any bolt" be sure it is the proper grade for the application.
Cordially Mike
Cordially Mike
04 Aug 2016 12:58 #31460
by ilikescars
Replied by ilikescars on topic Re: Bolt head markings
Thanks for the reply. Come to think of it: the bolts may be marked with a "30" same as Auburn.
03 Aug 2016 23:35 #31457
Replied by 1748 S on topic Re: Bolt head markings
I was told that any bolt on the engine will have a W on the head or could be plain too. The W mark is a raised letter too. Its not simply stamped into the head.. Sad too cause we sure could "make" head bolts or any engine bolt for that matter. I think the most important item on bolts is the thickness of the hex head other than the modern markings we see on most any new bolt today. But if your restoring a runner any bolt will work.
03 Aug 2016 21:56 #31456
by ilikescars
Bolt head markings was created by ilikescars
Hi: Anybody know if the bolts that hold the exhaust pipes to the manifold
on an 810-812 have any type of marking? Perhaps a "W"? Or maybe just plain?
Copper coated?
Copper coated?
