Steel Head Gaskets
29 Jul 2018 00:05 #35093
Replied by 1748 S on topic Steel Head Gaskets
Thanks Jim. I don't recall why but that is what I thought they were originally
28 Jul 2018 23:30 #35092
Replied by JIM.OBRIEN on topic Steel Head Gaskets
The original head gasket were copper sheets with a sheet of asbestos in between.
28 Jul 2018 11:44 #35086
Replied by Curt Schulze on topic Steel Head Gaskets
31-36 Auburn had cast iron blocks. the early cars had CI heads while the later cars had aluminum heads they all used copper head gaskets .
All had a 'W' on the head. That stood for Williansport. I guess EL owned that factory. I have some new marked 'W' hi- hex cad plated head bolts. Over the years a couple of Cord owners have bought them . They shortened a few as necessary.
28 Jul 2018 05:01 #35083
I don't recall what letter is on the engine bolts.I do know they could be several letter bolts or they could be plain too. The Cord Lycombing block is cast iron but the heads are aluminum.The head bolts are three different lengths and they are 7/16 national fine threads.
- Glenn Sledge
28 Jul 2018 00:22 #35081
by Glenn Sledge
Replied by Glenn Sledge on topic Steel Head Gaskets
A head gasket in my 1931 ohv V 12 Cadillac failed recently.
It was rebuilt in 2014 using Olson copper gaskets. It had
been milled flat. The suspected problem is that
builder reused original studs and bolts. Suggest
not doing same.
not doing same.
28 Jul 2018 00:05 #35079
Do Cords use 'W' head bolts like the Auburns ?
27 Jul 2018 22:24 #35078
Hello Ken. Thanks for this answer. My engine was assembled way back in 1961 from the best parts of two complete engines. My guess is my father and his business partner used the best of what they had. Many gaskets were made from the old yellow pages phone books of the era. So my feelings are they used old used head gaskets that were copper. My heads are original and in poor condition. I have not decided what heads will be used yet. I want the new style that gives more cooling capacity but that requires new head bolts and they are not original so they get a point deduction in judging.. so I'm told. Making a custom set of longer head bolts is plenty of work too but possible..
- Ken_Sayers
27 Jul 2018 21:39 #35077
by Ken_Sayers
Replied by Ken_Sayers on topic Steel Head Gaskets
I am assuming the block and the head are steel. If that is the case, I would suggest that you use the steel/asbestos gaskets. The reason you probably had to replace the old gaskets was due to electrolysis, the chemical reaction of two dissimilar metals.
21 Jul 2016 20:08 #31402
Steel Head Gaskets was created by 1748 S
I purchased a set of what I feel is an oem set of head gaskets. They are a composition gasket. The metal on top and bottom is steel and the material in between this sandwich appears to be asbestos.
The set I removed was a copper material and was wondering what is the preferred type of gasket for the 810 813 Lycoming engines. Thanks for any comments. Pics coming later.
