Gas Tank door details needed.
- Aris Loumidis
03 Jun 2016 15:40 #31224
by Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
1936 CORD 810 Phaeton
Replied by Aris Loumidis on topic Re: Gas Tank door details needed.
Fitted everything together today and thanks to you and our forum,I'm on my way.
I only wonder what is the need of the strap, since with the flat spring adjusted, the door stays open without falling back.
Need to re-chrome the hinge and some bits of the lock and then one more item on my to-do list will be crossed out.
Thanks Thomas!
Aris
Thanks Thomas!
Aris
Aris Loumidis
Athens, Greece
ACD Life Member
______________
- Thomas Wilcock
- Thank you received: 8
01 Jun 2016 11:51 #31199
by Thomas Wilcock
Replied by Thomas Wilcock on topic Re: Gas Tank door details needed.
The strap is attached to the top hinge bolt and not the bottom like I said in my previous post.
- Thomas Wilcock
01 Jun 2016 11:49 #31198
by Thomas Wilcock
The bottom of the strap has a rectangular metal plate over it with a metal screw going through. The top of the strap is not sandwiched between the hinge and door. The end of the strap is folded over and it goes on top of the door lip . The bottom hinge bolt goes through it with the washer and nut on top. These pictures are a little better focused and should show.
- Aris Loumidis
30 May 2016 15:23 #31185
by Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
Thanks for the picture Thomas, it now makes sense. Please be kind enough to clarify if the bottom of the strap is attached with a screw with washer and the top sandwiched between the hinge and the cover.
Aris Loumidis
Athens, Greece
ACD Life Member
______________
- Jazzman
30 May 2016 02:23 #31180
by Jazzman
I have heard there are 29,816 parts to one of these cords. Most of mine came ups..... and didn't fit
Replied by Jazzman on topic Re: Gas Tank door details needed.
Hi I believe in the restoration forum there are detailed instructions here on this site good luck Carlton
- Thomas Wilcock
29 May 2016 16:19 #31176
by Thomas Wilcock
- Aris Loumidis
29 May 2016 08:17 #31171
by Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
Gas Tank door details needed. was created by Aris Loumidis
Hi everyone,
I got the strap and the return spring that go on the Gas Tank Door, but dont know how to install them. Any help in the form of a picture or else, will be appreciated.
Here is a picture:
Here is a picture:
Aris Loumidis
Athens, Greece
ACD Life Member
______________
