Setting Points Gap
- Aris Loumidis
29 May 2016 08:43 #31172
by Aris Loumidis
Aris Loumidis
Athens, Greece
ACD Life Member
______________
1936 CORD 810 Phaeton
Replied by Aris Loumidis on topic Re: Setting Points Gap
Way back I installed the Pertronix electronic ignition and since then I forgot about this issue. I use them in four classics-drivers with excellent results. They go for $70-80, they are easy to install and you keep the original looks. I carry with me the original point plate just in case, but never had to use it.
Aris Loumidis
Athens, Greece
ACD Life Member
______________
- auburnandyscar
28 May 2016 03:17 #31167
by auburnandyscar
Check out my build at:
www.1932auburnsedan.com
Replied by auburnandyscar on topic Re: Setting Points Gap
I cannot see why not. I set all of my points with a dwell meter.
I'm guessing that "Fancy tools" like a dwell meter in the 1930's were pretty rare and expensive.
Pretty much every Mechanic had feeler gauges, and set with that, it would run.
26 May 2016 14:33 #31149
Setting Points Gap was created by 1748 S
Can we use a dwell meter to set the points gap on the 810 812 engines? I have wondered this for some time. It would seem like a better way of establishing the correct gap. Thanks.
