Piston Time
- xjn001
29 Apr 2016 10:24 #31024
by xjn001
Replied by xjn001 on topic Re: Piston Time
28 Apr 2016 14:36 #31020
by
Replied by on topic Re: Piston Time
Back in the day automotive machine shops could expand pistons using a shot peening process. You could check around to see if anyone still does it.
27 Apr 2016 22:58 #31017
Piston Time was created by 1748 S
What is a recommended brand of pistons and why? Also what piston brands should I stay clear of. My new set has about 5 to 6 thousandths clearance so I probably should replace them. Sad because they are new pistons purchased way back is early 1961. Rings on them are new also.
