Wheel torque settings
- GPM30236
02 May 2004 23:39 #1683
by GPM30236
Replied by GPM30236 on topic Wheel torque settings
thank you appreciate the assistance
- Auburn/Cord Parts
30 Apr 2004 19:02 #1671
by Auburn/Cord Parts
Replied by Auburn/Cord Parts on topic Re: Wheel torque settings
Lug Bolts are 9/16". Torque specs are 120lbs dry or 72lbs. with lubrication.
Front Hub Nut to U-Joint Stub should be 350lbs. Use a torque multiplier to achieve this spec.
Stan
Stan
GPM30236 wrote: Have not found the torque specifications for either the lug nuts or the front main spindle nut for my 810 in the service manual any advice?
- GPM30236
29 Apr 2004 03:40 #1655
by GPM30236
Wheel torque settings was created by GPM30236
