Drive unit serial number's
  • balinwire
  • Frequent Forum Contributor
24 Jul 2003 01:10 #522 by balinwire
balinwire created the topic: Drive unit serial number's
The body and engine numbers are very accurately accounted for in most databases. Is there any record of drive unit numbering? I would like to determine my gear ratio with the #?s. I see no representations or references in any source.
My job is listed as being in the factory getting a shift interlock in 1936 and has all 1936 features but is numbered in the 1700?s and the 1936 renumbered cars stopped at the 1500?s. So would I have the high,"early" tall gearing?
Would they have removed the entire drive case or modified the earlier case. Would they have used different or the same number?s on a new case? Everything else, fuel pump location, steering wheel, motor#'s indicates an 810 but with 812 improvments, front bolt saftey hangers, etc.
What significance do the drive unit #?s have? I have seen the first few cars built as being mentioned as having a #1 or #2 or #3 unit.
Did the drive unit numbering start a #1?
24 Jul 2003 12:19 #526 by Pat Leahy
Pat Leahy replied the topic: Cord transmissions
The best information I have found is in the club's 810'-812 transmission manual. Page #5 describes the different series and running changes.Every Cord owner must own one of these manuals. If you do not have one, there available from the membership secretary.
  • Auburn/Cord Parts
  • Auburn/Cord Parts's Avatar
28 Jul 2003 15:49 #549 by Auburn/Cord Parts
Auburn/Cord Parts replied the topic: Re: Drive Unit Serial Numbers
On Cord transmissions with the 47:10 ratio the ratio number is stamped above the serial number. If no ratio number is found, it should be the 43:10 ratio. The prototype or test mules used the #'s 1-6. Production units started at 100. You should read the Cord Engineering Notes, they're interesting.
Stan
  • balinwire
29 Jul 2003 00:35 #558 by balinwire
balinwire replied the topic: Engineering notes
Stan, you are truly the master. You were right, I could just barely detect the numbers, as they were very lightly stamped in the cast case, <R47.10> just above the deeply embossed Drive number?s T2592.
I presume the body must have been well along in the 812 assembly process to have the high serial # drive case and having the 47.10 gearing in a 37.
This would say to me that some of the old 810 car?s were released as 812 even as later then the 1500#?s. The body number is 812 1752A with original underhood components.
The car was mentioned in the 1936 shop fliers as a car that had a interlock installed 7/36.
So happy for the help. It would be nice if you could compile all of your many years of knowledge into some kind of a huge reference database.
Your the man, Stan, many thanks again. My next question may stump ya?.
acd cars rule! :^)
Time to create page: 0.067 seconds
