Starting Problems - Clutch Switch
  • Bill McLaughlin
  • Bill McLaughlin's Avatar Topic Author
  • ACD Club Member
  • ACD Club Member
02 Jun 2003 18:13 #333 by Bill McLaughlin
Bill McLaughlin created the topic: Starting Problems - Clutch Switch
37 Westchester
Thank-you all for the "starting problem" answers. I am starting to sort through and implement them now.
Extended question: Can the switch activated by / below the clutch effect starting the car ? Can / will it go bad slowly or is it an "either works or doesn't work" type of switch ?
Thanks !
Bill McLaughlin
  • Josh Malks
  • Josh Malks's Avatar
  • ACD Club Past President
05 Jun 2003 13:40 #348 by Josh Malks
Josh Malks replied the topic:
Are you using Startix?
  • Bill McLaughlin
  • ACD Club Member
  • ACD Club Member
05 Jun 2003 15:46 #351 by Bill McLaughlin
Bill McLaughlin replied the topic: Starting Problems - Clutch Switch
Yes, I am using Startix.
Bill Mclaughlin
  • Josh Malks
06 Jun 2003 13:06 #355 by Josh Malks
The clutch switch is not quite a simple on-off switch. Its internal contacts slide on the actuating rod, so it makes and breaks at different points depending on whether the clutch pedal is going up or coming down.
You can esily test the switch with a light or meter to be sure that it's making contact every time the clutch goes to the floor. (For adjusting the switch linkage see your Service Bulletins.)
Startix does often contribute to the problem. The main contacts get pitted and oxidized, among other problems. You might check with Jim McCarthy in MI at (810)735-9394. So far as I know he is THE Startix expert.
Time to create page: 0.108 seconds
