Headlight won't open
11 Jun 2005 18:00 #3231
by Josh Malks
Replied by Josh Malks on topic Headlight won't open
Do NOT remove the assembly (bucket) unless you absolutely must. First disconnect the cable at both ends (loosen clamp, wiggle wiggle, then pull. Now you can tell which of the three components: headlight mechanism, cable, or crank is tight.
- dougklink
11 Jun 2005 14:59 #3230
by dougklink
Doug Klink
Estes Park, Colorado
812 S/C Phaeton
Headlight won't open was created by dougklink
I have one headlight that opens smoothly but the left one won't budge. I'm assuming I remove the assembly from inside the fender well and fix it there. Is this usually (if there is a "usually") the mechanism or the cable?
Doug Klink
812 S/C Phaeton
