810/812 Fuel sending unit
- Kevin
25 Apr 2005 21:19 #3081
by Kevin
Replied by Kevin on topic 810/812 Fuel sending unit
Thank you all for the great feedback, now I can wrap up this portion of the project.
The original unit is so rust damaged that it may not be rebuildable, but I plan to research that out.
I was also able to locate replacement units here locally, but was unsure of the proper ohm range, so now that I know that I can order one and use it until the original can be rebuilt.
Thanks again,
Kevin
Thanks again,
Kevin
24 Apr 2005 16:04 #3075
by Tom Georgeson
Replied by Tom Georgeson on topic Fuel gauge sending unit
I had a ACD member in CA repair my unit. You can contact Jack Marcheski at 831-637-3453,. With a new brass float it was around $60.
Tom Georgeson
Tom Georgeson
- Jack Richard
24 Apr 2005 01:21 #3073
by Jack Richard
Jack Richard, D.D.S.This email address is being protected from spambots. You need JavaScript enabled to view it.
Replied by Jack Richard on topic Fuel gauge sending unit
Kevin-
J.C. Whitney sells one in their catalog - it is a universal unit which adjusts for different depths of tanks, and I was able to adapt it easily to my Cord tank. It fits the opening correctly with the same bolt pattern, and it the proper resistance for gauge operation. If you can't find it in the catalog, let me know.
Jack Richard
Jack Richard
- e merancy
23 Apr 2005 18:20 #3071
by e merancy
Replied by e merancy on topic 810/812 Fuel sending unit
Kevin the unit out of my car is a Stewart Warner ,at the full stop it reads point three ohms (.3) at the empty stop it reads one hundred point three ohms (100.3) Hope this helps ED.
e.merancy email
- Kevin
16 Apr 2005 01:16 #3044
by Kevin
810/812 Fuel sending unit was created by Kevin
Hello again,
I am trying to either locate a reproduction fuel gauge sending unit, or determine the correct ohm range so I can use generic unit and modify it to work in the place of the original.
Any information is appreciated.
Kevin <!-- s:?: --><img src="{SMILIES_PATH}/icon_question.gif" alt=":" title="Question" /><!-- s:?: --> <!-- s:idea: --><img src="{SMILIES_PATH}/icon_idea.gif" alt=":idea:" title="Idea" /><!-- s:idea: -->
