CAM Bearing
- Ivor
16 Feb 2018 07:47 #34193
by Ivor
Replied by Ivor on topic CAM Bearing
Great close up photos, the early eights had a full set of bronze camshaft bearings, it looks like the later ones had only the front bearing replaceable with the others being cast iron, initially bronze then steel backed babbit. I have attached info from the Auburn 8-77 handbook. Auburn service bulletin number 10 and two pages from the "manual for Auburn service mechanics8-98 and 8-98A"
14 Feb 2018 12:41 #34163
Replied by Curt Schulze on topic CAM Bearing
Many builders use bronze bearings in place of the babbit. The factory let the cam run in the cast iron block except for the front . Over time the the holes become oval and low oil pressure is a result. My builder puts bronze bushings in all of the cam bearings.
- curtiss
14 Feb 2018 03:19 #34161
by curtiss
Replied by curtiss on topic CAM Bearing
Thanks for the picture, that one almost looks like someone machined a bronze insert to go back in. I have heard of a few doing that.
- auburnandyscar
14 Feb 2018 02:35 #34160
by auburnandyscar
Check out my build at:
www.1932auburnsedan.com
Replied by auburnandyscar on topic CAM Bearing
Yes, the engine is being rebuilt in the shop. It is for The museum's 1931 Auburn sedan AKA "Education car"
- convertiblesforever
13 Feb 2018 03:54 #34152
by convertiblesforever
Replied by convertiblesforever on topic CAM Bearing
Is this engine going through a rebuild? Thank you.
- auburnandyscar
13 Feb 2018 02:35 - 13 Feb 2018 02:37 #34150
by auburnandyscar
This is a 1931 Auburn 8 that we have in the shop. The engine is/was not 100% original as the Pistons had been Knurled at some point.
This is what its' Cam bearing looks like.
Last edit: 13 Feb 2018 02:37 by auburnandyscar. Reason: typo
- auburnandyscar
11 Feb 2018 05:46 #34141
by auburnandyscar
It "Looks" like a (soft) Babbit press in unit to me.
It also looks to be in good condition.
Have you tried to dig your thumbnail into it?
We have a stock original 1931 engine apart at the Museum, I will try to remember to snap a picture of it on Monday for you
- curtiss
06 Feb 2018 03:51 - 06 Feb 2018 03:53 #34099
by curtiss
CAM Bearing was created by curtiss
I was down looking at one of my blocks and I was looking at the front CAM bearing. The crank and rods have been converted to inserts and not knowing what a babbot cam bearing looks like I was hoping one of you could be able to tell if this cam bearing is a babbott or a normal press in of some sort?
Last edit: 06 Feb 2018 03:53 by curtiss.
