Removing old running board rubber
05 Feb 2018 18:56 #34093
by RandyEma
Replied by RandyEma on topic Removing old running board rubber
Watch the temp of your torch as you can warp the metal. R
05 Feb 2018 13:53 #34091
by ilikescars
Replied by ilikescars on topic Removing old running board rubber
Curt's method is the best. It took me 10 minutes to do two runningboards by heating the underside first with a torch.
- pwrightII
27 Jan 2018 16:38 #34058
by pwrightII
Replied by pwrightII on topic Removing old running board rubber
Thanks Randy and Curt for the info. Pete
26 Jan 2018 12:44 #34048
Replied by Curt Schulze on topic Removing old running board rubber
Done this many times. Put a rosebud tip on your oxy-acetylene torch . Heat about 1/4 of the backside at a time. Scrape it off with a three inch
putty knife. It will take you about a 1/2 hour.
25 Jan 2018 22:39 #34046
by RandyEma
I think aircraft paint remover will remove it one layer at a time
- pwrightII
25 Jan 2018 21:20 #34045
by pwrightII
Removing old running board rubber was created by pwrightII
I am restoring a 1931 8.98 Cabriolet and wondered if any of you can provide me with a method for removing old running board rubber. I've read numerous methods on the internet but no one can seem to agree on a good method. I have no doubt I am in for some fun. Thanks in advance. Pete Wright
