Bad main bearing
- Forum Contributor
Less More
10 Dec 2017 02:15 #33850 by Terry Cockerell
Terry Cockerell replied the topic: Bad main bearing
During the current and first restoration of my 810 Cord I have decided to move away from babbit bearings all together.
The engine had been converted to modern big end shell bearings many years ago but retained babbited main bearings.
A "machine shop friend" is making new main bearings from phosphor bronze bar plus I am converting the block to full flow filtration as per Bill Richardson's guidelines. Babbit bearings were ok when there were no alternatives.
Preserving an engine these days is essential.
- curtiss
- Forum Contributor
Less More
18 Dec 2017 04:27 #33875 by curtiss
curtiss replied the topic: Bad main bearing
In case you are interested the last time I checked Doug had two Lafrance engines at the ACD Factory. Fairly reasonable back then.
Time to create page: 0.044 seconds
