Engine Stand for Auburn Straight 8???
23 Jun 2017 00:14 #33191
Replied by 1748 S on topic Engine Stand for Auburn Straight 8???
I have this exact engine stand. Its capable of holding 2000 lbs. I used it to rebuild my ford diesel V8 engine that weighs in fully dressed out around 100 lbs.
- curtiss
21 Jun 2017 18:06 - 21 Jun 2017 18:07 #33190
by curtiss
Replied by curtiss on topic Engine Stand for Auburn Straight 8???
Thanks for the replies, gives me some ideas.
Last edit: 21 Jun 2017 18:07 by curtiss.
- curt
18 Jun 2017 18:00 #33172
by curt
Replied by curt on topic Engine Stand for Auburn Straight 8???
There is a stand commercially available designed for the longer engines used in trucks. It has a sliding section at one end so the engine is secured at both ends
- Neal Ziff
06 Jun 2017 02:24 - 06 Jun 2017 02:27 #33118
by Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
Replied by Neal Ziff on topic Engine Stand for Auburn Straight 8???
Hi Curt,
I removed, rebuilt and reinstalled the straight 8 from my 1930 8-95 about 18 months ago. I used a standard engine stand and a sling from a cross beam in my barn to hold the front end. I also set it up on some sturdy saw horses for head work, etc. A load leveler made a huge difference in the process. That engine is long and heavy - be careful.
Neal
Neal
Neal
_________________
1930 8-95 Cabriolet
Last edit: 06 Jun 2017 02:27 by Neal Ziff.
- curtiss
05 Jun 2017 03:07 #33115
by curtiss
Engine Stand for Auburn Straight 8??? was created by curtiss
I picked up a spare straight 8 engine that I want to tear down, what are you all doing for an engine stand? Are you making something custom, please post picks if you have any.
