8-98A Running Board Side Stainless Install
  • Curt Schulze
25 Jan 2017 13:00 #32351 by Curt Schulze
Replied by Curt Schulze on topic 8-98A Running Board Side Stainless Install
Brad, you can buy parkerizing kits on eBay, the instructions are easy to follow.
Stainless steel blackening can be purchased at Caswell. This is even easier, no heat required.
  • Brad Hoskins
25 Jan 2017 01:59 #32348 by Brad Hoskins
Replied by Brad Hoskins on topic 8-98A Running Board Side Stainless Install
How does one 'parkerize ' a modern fastener? And can you do it with stainless if one was 'nuts' enough to ? Any tips?
I've painted other fasteners on the car but that is messy and , as I'm sure you know, doesn't look quite right.
Brad
31 8-98 cabriolet
  • Curt Schulze
24 Jan 2017 13:31 #32334 by Curt Schulze
Mark, your car takes 20. They are flat-sided bolts that slide down the channel. Use square nuts, all parkerized black.
My 31 and 32 are the same, but take fewer fasteners.
  • ilikescars
23 Jan 2017 22:40 #32328 by ilikescars
Replied by ilikescars on topic 8-98A Running Board Side Stainless Install
Prolly 10-15
  • curtiss
  • Premium Forum User
23 Jan 2017 22:34 #32327 by curtiss
Replied by curtiss on topic 8-98A Running Board Side Stainless Install
I will let you know, I have 2 more cars to do so I may have 10 or 15 extra clips. How many do you need?
  • ilikescars
23 Jan 2017 22:29 #32326 by ilikescars
I used the same clips, but instead of removing spring, I sanded off some of the top edge.
If you want to sell me the rest of your clips let me know. email is [email protected]
  • curtiss
23 Jan 2017 19:45 #32325 by curtiss
Thanks for the answers and pictures, Debby and I got them drilled and installed last night. I ended up having to use some Chrysler molding clips I picked up from Fasenal to slide into the outer strip. I had to cut off the spring end but they worked great.
Had to buy a box of 50 to get 10 :)
Molding Clips
Chrysler: 1624705 6010093 Universal Moulding Fastener
  • johnmereness
22 Jan 2017 18:52 #32315 by johnmereness
Replied by johnmereness on topic 8-98A Running Board Side Stainless Install
On an 851 and 852 I believe the original nut is square - you may want to ask about what is original 31 /32.
  • curtiss
19 Jan 2017 23:21 #32312 by curtiss
Awesome, thanks for the pictures!
  • Rlamb10769
  • Senior Forum User
19 Jan 2017 17:16 - 19 Jan 2017 22:32 #32306 by Rlamb10769
Replied by Rlamb10769 on topic 8-98A Running Board Side Stainless Install
Attachment not found
I have attached a photo of my SS attachment, there are five of them..
Richard
Richard
Richard Lambert
ACD #3371
Last edit: 19 Jan 2017 22:32 by Rlamb10769. Reason: Add photo
  • ilikescars
19 Jan 2017 14:33 #32304 by ilikescars
Curtiss: On my 36 Auburn, I ended up drilling extra holes near the ends of the trim to help hold the trim in tighter.
Then re-positioned the fasteners as needed. (No one noticed the difference in the amount of holes)
  • curtiss
18 Jan 2017 17:30 - 18 Jan 2017 17:30 #32294 by curtiss
I just received new running board side stainless and no holes were pre-drilled. I picked up some molding mount clips from Fastenal that look like they will work to secure the outer molding so not I need to figure out how many holes were typically drilled to mount these.
It appears in the last restoration the old holes were filled in so would one of you be able to look to see how many studs you have holding the running board stainless on?
Thanks!
Last edit: 18 Jan 2017 17:30 by curtiss.
