Auburn VIN codes
- brick
18 Sep 2004 16:13 #2237
by brick
Replied by brick on topic Auburn VIN codes
Thanks for your advice, helped a lot.
R.Ruzicka
R.Ruzicka
16 Sep 2004 00:41 #2227
by RandyEma
Replied by RandyEma on topic Auburn VIN codes
Hello I have no record of a 1932 Auburn speedster with that serial number . Buyer beware Good Luck Randy Ema
- Auburn/Cord Parts
15 Sep 2004 14:50 #2224
by Auburn/Cord Parts
Replied by Auburn/Cord Parts on topic Auburn VIN Codes
As already posted, the serial number is incorrect. The ending "A" represents a sedan.
Stan
Stan
- archiespalace
14 Sep 2004 17:35 #2212
by archiespalace
Replied by archiespalace on topic auburn speedster
To identify car,check body plate...serial number is followed by a letter .In speedster case,it should be "E".Beware of phonies !
- pwright
14 Sep 2004 12:01 #2208
by pwright
Replied by pwright on topic boat tail
You might check with Randy Ema. He has a remarkable record of Auburns
- brick
14 Sep 2004 11:46 #2207
by brick
Auburn VIN codes was created by brick
Hi, i was offered a car, which is presented by it s owner as a 1932 Auburn boattail speedster.Since i have only a little theoretical knowledge about Auburn body,frame and engine No. system,i would like to ask if someone can help me with the vin codes.The only info i have is,that the body No is : 8100AG348A.Is there a way how to identify only by checking VIN if the car is correct?
On one hand,I m interrested in purchase of Auburn, but only original car-not a replica or complete or partial rebody.
Any halp is appriciated.
Thanks,greeting
R.Ruzicka
Thanks,greeting
R.Ruzicka
