Replacement Radiator Hose Petcock 8-98
04 Aug 2016 16:15 #31462
Replied by Curt Schulze on topic Re: Replacement Radiator Hose Petcock 8-98
I took a quick look and thought it was the radiator. Randy, you are absolutely right !
I stand corrected. A PF-4 plug is it .
04 Aug 2016 15:59 #31461
by RandyEma
Replied by RandyEma on topic Re: Replacement Radiator Hose Petcock 8-98
Curt Is correct for the radiator drain but you were working on the water pump which is a pipe plug. R
04 Aug 2016 11:47 #31459
My 898 came with a radiator drain cock H1-217 which is the same drain cock that was carried into the 34-36 6 & 8 cylinder cars.
H1-217 is in the 898 Auburn parts list page 58.
New ones are available.
03 Aug 2016 19:38 #31454
by RandyEma
Iron Plug
- curtiss
- Premium Member
03 Aug 2016 15:14 #31453
by curtiss
Replied by curtiss on topic Re: Replacement Radiator Hose Petcock 8-98
Randy, would the plug have been steel or brass?
Curt Curtiss
Curt Curtiss
- curtiss
- Premium Member
03 Aug 2016 15:06 #31452
by curtiss
Awesome, thank you!
03 Aug 2016 14:59 #31451
by RandyEma
Hello It was originally a square headed pipe plug. No pet cock. Randy
- curtiss
- Premium Member
03 Aug 2016 14:48 #31450
by curtiss
Replacement Radiator Hose Petcock 8-98 was created by curtiss
I have a leaking radiator hose petcock on our 1931 8-98 and I was hoping one of you know the size and thread so I can order one?
I see one here that looks similar but not sure if it is 1/4 NPT or something bigger.
classicandexotic.com/store/p-53-14-pipe-...ard-v-12-engine.aspx
