Heat Control Question
- curtiss
05 Jul 2016 14:26 #31351
by curtiss
Replied by curtiss on topic Re: Heat Control Question
I did see the IM, actually Peter Kelly had two that I bought. Thanks for the lead!
04 Jul 2016 03:41 #31342
Replied by mikespeed35 on topic Re: Heat Control Question
Maybe a contributing factor but not the only problem. Did you get my message about a dist. currently on ebay?
Cordially Mike
Cordially Mike
- curtiss
03 Jul 2016 22:18 #31338
by curtiss
Heat Control Question was created by curtiss
While chasing my running hot issues I noticed a stray cable attached to my heat control switch at the dash. When I read the book I understand it helps heat the motor in cooler weather. Mine is lever on the manifold is broken off and I have no idea if it is on or off.
My question is if it is on will this contribute to the running temp of the car or will it just heat the intake and carb?
