Running Board Rubber???
  • vintagerodshop
  • Junior Member
29 Aug 2016 13:26 #31622 by vintagerodshop
Replied by vintagerodshop on topic Re: Running Board Rubber???
curtiss wrote:
vintagerodshop wrote: Hi Curtiss, Try Rand Broadstreet. I purchased new running board mats for my 1932 8-100A Boattail and was very pleased.
Kirk Stevenson
Kirk,
What glue did you use to install the new ones, any suggestions on installation process?
Hi Curt, The first time i used a two part epoxy that Rand Broadstreet supplied with the mats. the second time [on a different car] I used contact cement. Buy fresh from local hardware store. also make sure you take sandpaper and scuff the underside of the rubber mat.
  • Curt Schulze
26 Aug 2016 11:44 #31604 by Curt Schulze
Replied by Curt Schulze on topic Re: Running Board Rubber???
The stainless steel strips can be had from Northfield Forming in Ohio. Yes, for best results remove the running boards.
  • curtiss
  • Premium Member
25 Aug 2016 19:51 #31601 by curtiss
Replied by curtiss on topic Re: Running Board Rubber???
OK, my new covers arrived and they are much different than what is currently installed. My current covers do not wrap over the outer edge and there is a small space of metal showing where the running board meets the front and rear fender.
It looks like you need to remove the running board to install new covers, is that how you all did it?
I also have to track down the stainless strips that go on the outer edge over the rubber.
  • curtiss
  • Premium Member
21 Aug 2016 15:58 #31573 by curtiss
Kirk Stevenson
Kirk,
  • curtiss
  • Premium Member
16 Jun 2016 18:14 #31279 by curtiss
Kirk Stevenson
Thanks, I will check them out.
  • vintagerodshop
  • Junior Member
16 Jun 2016 13:38 #31278 by vintagerodshop
Kirk Stevenson
  • curtiss
  • Premium Member
14 Jun 2016 13:47 #31269 by curtiss
Running Board Rubber??? was created by curtiss
It looks like some of the rubber on my running boards has shrunk a little. I thought about finding a quality rubber and cutting new strips but not sure the best material to purchase.
Any suggestions on the best place or type of rubber to purchase?
