Removing the Steering Box on a 1933 8-105
- curtiss
- Premium Member
06 Jun 2016 21:15 #31237
by curtiss
HAHA, hey I will take any information at this point. I am used to working on 50's and 60's muscle cars and this is a new animal for me.
It was actually a very tight fit, I almost gave up.
Replied by curtiss on topic Re: Removing the Steering Box on a 1933 8-105
ilikescars wrote: Great job! I didn't think that could be done. Sorry about the misinformation. <!-- s:oops: --><img src="{SMILIES_PATH}/icon_redface.gif" alt=":oops:" title="Embarassed" /><!-- s:oops: -->
06 Jun 2016 20:35 #31236
by ilikescars
Replied by ilikescars on topic Re: Removing the Steering Box on a 1933 8-105
- curtiss
- Premium Member
06 Jun 2016 13:15 #31234
by curtiss
UPDATE: The great news is I did not have to remove the engine
Here is what I had to do:
- Remove the oil jacket on the side of the block (2 bolts)
- Remove the cover of the steering box
- Remove the column dash bracket
- Remove the steering wheel
- Remove the front seat
- Remove the arm from the box
- Remove box mounting bolts
- Twist the box around as it is pulled out
I ended up having to twist the box all the way around and it lifted up and pulled out. It very tight but I was able to get it out.
06 Jun 2016 10:53 #31230
by ilikescars
I think you have to have the engine out. Curt may weigh-in on this
- curtiss
- Premium Member
03 Jun 2016 02:36 #31220
by curtiss
Removing the Steering Box on a 1933 8-105 was created by curtiss
I am going to be removing the steering box on my 1933 8-105 and I am looking for advice and any secrets you have learned. It looks like a bit of a tight fit on the engine side.
I have removed the drag link and plan to remove the steering arm from the box but I need to get a shorter 2 prong puller tomorrow. I have the wheel off and the column loose.
My question is can I get it out with the engine in place, I am guessing I can twist it enough to get the rod coming out of the box back through the frame?
