- Thank you received: 8
Trico wiper on Auburn
- Justin Kerns
05 Apr 2016 14:39 #30920
by Justin Kerns
Justin
1932 Auburn 12-160A Sedan
1933 Auburn 12-161A Sedan
Replied by Justin Kerns on topic Re: Trico wiper on Auburn
Very interesting - thanks to you both. I will check my parts book. I'm surprised that the "T" would be behind the dash since this is a closed car. That makes perfect sense for an open car. But there is already a hard line plumbed up through the driver's A pillar and across the windshield header to the driver side motor. It would be much, much easier to have the "T" behind the windshield header and run a second line straight over to the passenger side motor. Running another hard line up through the passenger side A pillar seems like a lot more work but perhaps there is something I'm missing there.
I'll consult my book and take a closer look. Thanks!
Justin
05 Apr 2016 11:46 #30918
Replied by Curt Schulze on topic Re: Trico wiper on Auburn
The part number for the vacuum 'T' under the dash has a p/n G1250 Which is a 34-36 p/n.
Justin, look in your parts list and see what it says. I have a 898 book, but it doesn't show your car.
04 Apr 2016 23:26 #30916
by ilikescars
Replied by ilikescars on topic Re: Trico wiper on Auburn
There should be a little brass T behind the dash, which will help connect the two motors. Rubber vacuum lines will run off the T to the two wiper motors.
- Justin Kerns
04 Apr 2016 18:22 #30915
by Justin Kerns
Justin
Thanks for the feedback gents. I will contact Kent to see about having the motors rebuilt since I definitely hear a leak whether the motor is switched on or not.
The other thing I need help with is the vacuum connection between the first motor and the second. I'm not 100% sure how that works and whether I need a hard line or just rubber between them. It's one of the things we're trying to piece back together on this car. Does anyone have a 2 wiper setup on a 31-33 Auburn sedan that can advise or share a photo?
Justin
01 Apr 2016 11:50 #30912
I would suggest getting the wiper motors rebuilt. I have had dozens of Trico's rebuilt.
Kent Jaquith summer (Clean Sweep) 2633 SW Obsidian Ave. #15 Redmond OR 97756 541-548-1010 Kent cell 541-923-4319
01 Apr 2016 04:16 #30911
Replied by mikespeed35 on topic Re: Trico wiper on Auburn
You should hear no hissing. That is a vacuum leak of course. If this leak is constant, even when the wipers are not on your idle and general running of the engine will be affected.
Cordially Mike
Cordially Mike
- Justin Kerns
31 Mar 2016 15:54 #30907
by Justin Kerns
Justin
Trico wiper on Auburn was created by Justin Kerns
Hi everyone,
I'm trying to get the wipers going on our sedan. I've inspected and lubricated the wiper motor however it still won't move freely enough to perform properly. I can't tell if the leather flapper is too large and has too much friction or if the car isn't pulling enough vacuum for the motor to operate properly. At idle I'm showing 14-15 lb-Hg of vacuum at the wiper motor inlet hose. I have no idea if that's sufficient or "normal" idle manifold vacuum for the 12 engine or not.
One thing of note is that I hear hissing around the actuation switch when idle and also when operating the switch. Is that normal? Seems like a vacuum leak at that point that could be impacting things? All help is greatly appreciated!
Justin
