'31 Gas tank cover
  • convertiblesforever
18 Nov 2015 03:15 #30611 by convertiblesforever
Replied by convertiblesforever on topic Re: '31 Gas tank cover
Thank you all. I will use it as it does fit under the coupe body and all mounting holes line up.
I appreciate your responses.
Glenn
  • RandyEma
  • Duesenberg Historian
15 Nov 2015 21:48 #30593 by RandyEma
Replied by RandyEma on topic Re: '31 Gas tank cover
Brad has it real close but it is the coupe cabriolet and sedan have one length and the brougham and phaeton sedan share the deeper splash apron. Randy
  • Brad Hoskins
15 Nov 2015 18:19 #30591 by Brad Hoskins
Replied by Brad Hoskins on topic Re: '31 Gas tank cover
Or phaeton!
The coupe and cabriolet have an extended rear body to accommodate the trunk/seat lid. The sedans and phaeton 'cut ' back under the rear seat. That's why the trunk racks and rear bumpers are different as well
Brad
31 8-98 cabriolet
  • johnmereness
15 Nov 2015 17:00 #30587 by johnmereness
Replied by johnmereness on topic Re: '31 Gas tank cover
It is either for a Brougham or a Boattail (a shorter style body than a coupe, convertible, or sedan).
11 Nov 2015 01:56 #30570 by convertiblesforever
'31 Gas tank cover was created by convertiblesforever
Recently I picked up a nice gas tank cover for our '31 Coupe project. When I compared it to the original damaged original I found that the replacement is 6-1/2 inches longer. All else is the same. The new lid fits nicely under the car with the body hiding the extra material. Can anyone offer the reason for the extra length on the new tank cover?
Thank you.
